Jan 2017
I am about to purchase a Cubify sense 3D scanner for the sole reason of 3D scanning an entire human.
My question is if it it possible and if so, what are the results with the mesh and texture of the scanned person?
Thanks,
Daniel.
    Jan '17
    Jan '17
  • 11
  • 2.0k
  • 11
Hi Daniel.
I tried that by myself but did not come up with a reasonable result. The Resolution is too low and Details get lost in the mesh. You have to scan very slowly which is not so easy on a human body (movements) otherwise the scanner will loose tracking and that is very annoying.
Cheers - Dietmar
Hi Daniel!
The definition of the mesh depends on many factors, exposure, light, contrast etc.
I do not know well your scanner, but usually requires a post processing to fix various bugs mesh created by the scanner. In general, the scan is not an easy and requires a lot of experience and testing process.
Marco
check this site: 3D Scan Expert 2 there are a lot of reviews about 3d scanners.
depend by what You are going to do with that mesh
a structured light scanner like einscan,scan in a box or david can give e really detailed mesh good for mechanical use, the other scanners are not able to catch all details, but maybe you need olnly a not detailed mesh with a related texture.
Hi Daniel,
I’ve the Structure Sensor and I use it to scan people in 3d, it’s not perfect but it give a good result.
You can find Nick’s review here : Structure Sensor 3D Scanner Review & Tutorial - 3D Scan Expert 1 (he’s the person you want to ask for everything related to 3d scanning).
I advise you to check the itseez3d app too, used with the Structure Sensor it’s really easy to scan people.
To have the best results, it helps to have some good lighting too.
Cheers
Yann
Better to buy Skanect software and Xbox 360 Kinect. Better software better results. You can use ISence with Skanect too. That is what I use.
Don’t buy it. Doesn’t work as advertised. Can’t get ours to connect. Customer support is never there. Go with something else.
