Aug 2017
Thanks for the info about makerbot print. I’ve been using the SD card this whole time, but support (who have really been on my nerves throughout the whole troubleshooting process with the first printer) told me Print wouldn’t be compatible regardless.
I’ve been playing with the leveling (specifically not letting the nozzle get too close to the print bed) and will try it again and see if that helps with the surface quality. How often would you say I should relevel? Between every print?
When I’ve got time later, I’m going to make a quick little test print and try slowing the print speed, as well. I’m just a bit worried that, because there is filament leaking and clumping in whichever nozzle is idle during printing, that these clumps might harden and make worse drags during the print.
1. Have a look here:
https://support.makerbot.com/learn/makerbot-print-software/release-notes/makerbot-print-release-notes\_13553
The downside is that makerbot print doesn’t support both nozzles as far as I know.
2. Does the filament leak out of the nozzle or between the nozzle and the heat-block?
3. Look at this video of leveling:
and also this video for leveling between nozzles:
Usually if it’s making blobs while printing then your nozzle is to far away from the bed…
Filament will almost always leak when at rest, you can drop the temp and see how it reacts but a little oozing filament is pretty much normal operation.
It’s not as much a big deal during preheat as it is during the actual print. The idle nozzle almost always has leaking filament that tends to clump and drag across the print surface with the nozzle (you can kind of see the drag marks on the coin).
1. I know that some of the prints we’re going to require will need dual extrusion, so I guess I’ll just stick with Makerbot Desktop.
2. It’s leaking out of the nozzle, not near the heat block. And the leaking happens with the IDLE nozzle, the one that shouldn’t be extruding any filament while the other nozzle extrudes. That’s when the resulting clumps drag across the print (getting stuck in it) and become a problem.
3. I’ll definitely relevel. I felt like it was pretty well leveled for the most recent test print, but it can’t hurt to try again. My tendency is too level with the nozzle too close to the printbed, so that’s what I’m usually wary of.
It’s normal to leak a little during heat up but generally it should go straight down, if your level is good the string or blob will come off when the print makes that initial priming line to get things started.
so what we’ve established so far:
1. Properly level the bed
2. Properly level the extruders between each other.
3. Maybe sllow it down a little.
other thoughts:
4. Make sure your filament hasn’t absorbed any moisture:
https://www.matterhackers.com/news/filament-and-water 2
5. Consider ordering PETG from micro center, PET is a filiment with the strength charitoristics of abs but the print characteristics of pla. For your purposes it can be considered a direct replacement, I have a 2x and 2 5th gen printers and 1 6th gen printer and I love PET!
I used some foam as a dust filter for the filament, but hadn’t even thought about humidity effects. I’ll unload and store it in a drawer or something when not printing, probably with some desiccant for good measure. Thanks so much for your advice : )
First question (not a criticism): Was there a reason that the company chose the MB 2X? Unless ABS plastic was a requirement, it is in most cases, best to start with a PLA printer. There are arguments to this topic, but using a PLA printer is easier, especially if your are new to 3D.
The X in the 2X denotes Experimental. It’s best to consider it permanently as a “Beta” release of MB’s dual extrusion machine; and purposely so. ABS is more susceptible to ambient conditions, slicing programming, tolerances…stuff. It’s a tinkerer’s printer for those with some experience,interest and time to Experiment. I work with groups new to 3D and I, and my fellow volunteers, always recommend a single extruder PLA machine.
As noted in other comments (I may be repeating advice of others, sorry) make sure you have the latest firmware update.
Makerbot has a new desktop for slicing: Makerbot Print. But, I would recommend firmly that you use the original Makerbot Desktop for the 2X. It’s tried and true and is hand-and-glove with the Replicator 2 through Replicator 5th Gens. Run through set up again. When setting nozzle height, the friction created using the piece of paper as the measurement should be SLIGHT. Too tight and your just making the nozzles plow through the paper, essentially in a furrow.
Keep us updated:)
I completely agree with you in that we should have started with a single extruder printer, especially since no one here is particularly experienced in actually running a 3D printer. I’ve been told that multiple people in another engineering department also wanted to make use of the printer, did their research and recommended the 2X to the person making the purchase. Why they would recommend an experimental printer to people new to printing, I have no clue. If I had been told ahead of time that we were interested in a 3D printer, I would have asked for a recommendation from my former professors, who bought PLA printers that I’ve personally seen great results from. The stronger the better for our purposes, so we should have gone with PLA.
Based on the responses I’m getting, I think I’m going to be tinkering with the leveling a lot. I had it way too far away when I first leveled it (could get the print to stick), but the leveling has been tricky to perfect so far and I have a feeling these surface issues might not be as bad if I brought it up a bit more from where it’s set now. I realize it’s an experimental printer, but I feel it should be able to produce better quality prints than this.
Thanks for the tips : ) I’ll play around with more prints tomorrow and see if I can get better results.
Common problem; to many cooks in the stew. And engineering departments are notorious for bulking up on whatever gadgetry they can get for a certain budget at the expense of others who’s job does not require any expertise in the technology. I see it in schools, a lot. They’ll spend $10k or more on a Stratasys (MB’s Parent co.) and then spend and inordinate amount of time learning to run it - in lieu of spending a few thousand for a Makerbot, in this case - and accomplish the same thing.
Regardless, remember to adhere to the leveling plate procedure, and that the drag the nozzle creates on the paper is slight. The way I judge slight is sliding the paper - after each adjustment of the screws - into the space between the nozzle and plate to anticipate ANY resistance entering that void. Stop. Move on to the next (adjusting while letting the paper remain in place during each adjustment of the screw is deceptive. The nozzle compresses the paper at the point of contact - essentially negating any progress you’re making).
TIP: After completing the entire leveling process, there may still be one nozzle that feels a bit tighter than the others. Go ahead and tweak that one and call it good. That should eliminate the Z from your troubleshooting.
jimrittenour@yahoo.com
Thanks for these “updates” 360 alaska! I hadn’t seen the dual extruder ‘fix’ before- other than written form. Obviously, according to the change dates/“improvements” these people have no clue what they’re doing. I installed Sailfish, ( took me a while- 2x runthrough) but iz kool cuz I can adjust ‘on the fly’ as a CNC Mill. and I’m also running Vesion 1.35 as my slicer. As mb will no longer be supporting “old” equipment, I am moving to a different, smarter company.
Zortrax makes really good ABS printers, perfect prints almost every time and really easy to use. Not trying to promote Zortrax since now I mosty use the ultimaker 2+. I recently bought the BCN Sigma r17 but had all sorts of issues with it and ended up returning for ultimaker 3.
