Jun 2017
Probably around 3-5 mm. Type of glass will make a difference though. If you are only going to print PLA or other materials that won’t require a bed then any glass should do. Otherwise most tempered glass will work up to 80C. Anything higher than 80C for a heated bed I would recommend going with Borosilicate.
We are going to print ABS, PLA and other exotics.
Would a 9" x 6" work from this link? What thickness?
Thanks.
The zero maintenance way:
Step One: Print a Shim
FlashForge/PowerSpec glass-bed z-axis shim by johngiachero - Thingiverse 414 (or any other z-axis shim, we have our own for internal use)
Step Two: Clip the glass on with anything
https://www.amazon.com/photos/share/WBG2CopgmcCQNE1I87e3QLrVw10XImMo62hhj2uX7cX 138
Step Three: After about a dozen prints we can remove the clips as the bed gets adhered with PVA/Aquanet.
Swapping the glass every month or two is just using a paint scraper to pull off the glass and then repeating steps 2 & 3
