Jun 2015
Hi Arnoldas,
How many times (maby in %) your prints went wrong on Form1? Ive got Form1+ and for me its like 90% of prints are failed. Im trying to work it out but im not happy with my printer
This printer cannot effectively print anything larger than a golf ball. If the slices get too large it just causes too much suction. I fought with them till they gave me my money back. I bought it to print fixtures I had designed for the CMM I run. I had made the designs as skelital and open as possible to create the smallest possible area in each slice, however the prints still failed. After a great deal of research I discovered that I wasn’t the only one with this problem. They will jerk you around there and tell you that they don’t have that problem and say that they will help you to figure out what is going wrong. Luckily I did the research on the forum in the first few days. That said I still had to fight with them and threaten legal action. The printer absolutely cannot use the advertised build volume, and when I contacted them about a return they told me that they cannot accept returns on the printer once it’s been used. I had to threaten them with legal action before they changed their minds and let me return the printer for a full refund.
The form 1+ can happily use it’s build volume. On several occasions I’ve printed large objects taking up most of the volume. My largest used around 350ml of resin and took around 14 hours to complete on the 100 micron setting. It came out perfectly.
I would suspect that this was down to operator error.
Do you expose the PDMS to air before each print? I was having many failures before making sure to do this. With resin in the tank you should use the provided scraper and run it over the PDMS layer exposing it to the air. Do this for a good few minutes. This is also good practice as the pigment in the resin drops out over time to sit on the bottom of the tank obscuring the laser from properly setting the resin.
You may also need to filter your resin. I filter mine through a 125 micron paint filter after every couple of prints.
Have you calibrated the z axis? I had problems getting prints to stick before calibrating the Z axis to move it closer to the tank.
How do your prints generally fail?
11 days later
1 month later
2 years later
i actually strain, peel and check my Form1+ Vats with paper business cards or Uno cards since they have rounded edges. Cards don’t hurt the PDMS layer and work pretty good for straining and large chunks , although a paint filter is great for filtering the resin.
