You hit the nail on the head though, small objects regardless of complexity tend to work. I printed extremely complicated small objects with no problem, and even printed several small objects at the same time with no problem, it wasn’t until I started getting into larger single slices that I ran into trouble. The problem is the peel step. If you get to where you have larger slices, the peel step can either not completely separate from the tank, or it can cause a bounce that will throw the machine out of calibration. You can build large objects so long as they are lattice structures, it’s why their test model of the Eiffel tower works so well. They make sure this stuff is not out there and super easy to find, but if you go to Google and type in Form 1+ failures, you’ll find form posts all over the place with people having the exact problem, and telling just about the same story of talking to support, being told that it must be user error, and to send them the models, and after a time finding that the printer just won’t do it, if they get a response at all in those cases. I was lucky and discovered all of this quickly and forced them into a corner where they had to refund my money.
Can i ask if you filtered your resin through a 125 micron filter or similar? Did you also expose the PDMS layer to the air? I had many failures before doing both these things regularly. I haven’t found the orientation of the model to be all that important at times. I have found that conditioning the resin and the tank makes for more successes.
I did the steps where I used the scraper to expose the PDMS to air between every print and actually thought I was having trouble with particles in the resin and completely cleared the tank of all resin, throwing away a small amount in the bottom of the tank, and starting with new resin straight from the bottle. Followed all the instructions to the letter, and had no success. After hours of research and almost an entire bottle of failed prints, I decided to move on and look for a printer that would serve the purposes I needed.
Cleaning it with alcohol should not be a problem. The resin is cured. The only real risk is not getting the uncured resin completely off it and catching little drops of alcohol in with the resin and then introducing the alcohol to the resin tank.
Another options would be to wipe the comb off as best you can and then set it out for the remaining wet resin to solidify in UV light. When it gets too clogged, toss it and use a new one.
I’ll get to you on monday when ill be back in my place, and ill show u the pictures. Yest i was filtering the resin (i dont remember hole sizes but ill check it on monday. I was exposing PDMS to air. Nothing works. Some print are better the others but generaly its not working right…
I think I’ll give your second option a go. Is there anything else your using to clean the resin tank?
I printed that comb and have a word of caution. I had used a regular comb before, it was cut to width and worked well. This one printed great on a replicator after I sliced the back flat. I could not get it to fit in my Form for printing. I went to use it with clear resin the way I had used the hair comb and moved it too quickly causing a wave to go over the top front edge of the tank.
The tank was on the machine because it had become stuck in place. There was no amount of prodding I could do to get the tank loose. I ended up sawing a tab off one side, removing the top, front and back covers, removing the 4 nuts that are spring mounted under the tray frame to finally get the tray and frame out. After pouring the resin out. I proceeded to use the metal spreader and an exacto knife to break the surfaces between the plastic tray and metal frame. It was covered with semi cured resin. To do a thorough cleaning job I bought denatured alcohol to soak the metal frame in. It turned out part of the problem getting the tank out is that the spring loaded ball bearings in the metal frame had become stuck and would not move any longer. That got fixed.
As a preventative measure I applied some silicone lubricant to the ball bearings and will no longer be leaving my tank of clear resin in the printer for extended periods of time.
Thanks man!
Exactly the same things, we are facing. Larger models tend to fail the reason we figured is also the peeling process. what a shame. Since on 3D Hubs you get queries from people believing in Formlabs advertisement and somewhat expecting these result… quite hard to explain to them, that its not that easy.
Using the Scaper from the Finish kit that you get with Form1+ used to work decently as well
I am sorry to hear that this happened. It must have been a pain to deal with this…
Let the comb dry after (a short) IPA bath.
Yes, uncured+IPA in the resin tank will be a bad mix.
i actually strain, peel and check my Form1+ Vats with paper business cards or Uno cards since they have rounded edges. Cards don’t hurt the PDMS layer and work pretty good for straining and large chunks , although a paint filter is great for filtering the resin.
