Jun 2015
When printing I am getting ripples that are diagonal, not fully horizontal like on Z wobble issues. I believe it is a problem with my extruder - under extruding then overextruding. I have adjusted and readjusted the extrusing in firmware and tried messing with the ex​tusion multiplier with no success.
Anybody got any thoughts?
    Jun '15
    Jun '16
  • 46
  • 14.8k
  • 22
I have a possible issue in mind, but I don’t know, if that could really be, what we’re seeing as those errors.
Is your printer a bowden or direct drive printer ?
When extruding, does the extrusion motor make a smooth rotation, or is it more like “jumping” to a specific angle, then stopping and again jumping ?
What layer height, nozzle diameter, filament diameter and printspeed do you use ? Also it would help to know the material and print temperature, did you test other materials and varying any of the settings mentioned above ?
I hope, that I can help you, but I need those informations, to make up theories and to think them through (+figuring out a solution)
Marius Breuer
Try reducing the stepper pot for your extruder driver - I had the same thing happen on my machine and it went away once I dialed back a bit. Also, you may want to do a PID calibration on your hotend - thermal cycling can make patterns like that as well.
Hi Christian,
I believe that the origin of your problem is in the extrusion mechanism. Perhaps a problem with the gears. In the Wade extruder, for instance, I think to the little gear having a problem on a tooth.
Perhaps, also, the pulley not well fixed on his axis.
Due to the regularity of the problem, I believe it’s a mechanical one.
Hope to have helping you, best regards, Jean
PS : Sorry for my bad English!!!
This could also be caused by retraction settings, try running with no retraction at all, at least you can eliminate this a s the problem if there is no change on your calibration print.
As all previous comments I agree that it is very likely an extrusion problem. The extruder is either pulsating or you try to push the extrusion too hard. I.e. Print slower and see if that helps. Of course you can try other pla plastics that are more friendlier to extrude. Especialy light colors like white give better results and require less extreme temperatures. White extrudes nice at 190 while black requires higher temp like 210 degrees celcius at 40 mm/s printing speed. Cura has a nice feature that allows you to tune the extrusion (extrusion percentage).
Good luck with trying all the suggested comments, i am sure you quickly find the problem and let us know what it was.
No, that’s very odd. I’d be interested to hear what others have to say.
It may be simple. The first thing I thought of is the bed may not bed level and/or the nozzle is not quite close enough to the bed. I’m sure you’ve already checked that though. :slight_smile:
Good luck!
-Michelle
If it were an extrusion problem, this would happen if your seams were lined up (each layer starts in the same place), but would not appear to be so regular if each layer started in a random location. In the pictured print, does each layer start in the same location? If so, try another print with randomized start points, so you can isolate the cause.
I have had very similar issues. Your problem is either 1) Your extruder is not firmly held in place so as it moves throughout your print the head will tend to wobble and move around. 2) Your belts are not tight enough resulting in lash which can and will cause things like I see in your picture to happen. 3) Your z axis rods are misaligned. You can check this by moving the z axis up and down and visually seeing if your y axis wobbles as it goes up and down. This is unlikely, as it would not cause the pattern I see in your photos…Trust me, this is not an extrusion problem. It is a problem with alignment and tightness throughout your printer
Also, your belts may be already tight. Check the fasteners that hold the belts to the carriages. One of these may be loose causing excess lash
I just dealt with this on a solidoodle 3 (direct drive extruder). It was a failing extruder stepper driver. I replaced it and the pulsing went away.
To be honest your extrusion looks not bad Are the parts well bonded If your having extruder problems other things typically go wrong this is very consistent I had said to check your belts I am sorry for the double post But your bearings could be warn or loose in there mounts
Adjust your X and Y motor pots on your board. This happens when your motors are pulsing from the lack of current, giving you the “moire” effect. *edit* Down voted for no reason. Guess I won’t give any advice here anymore
Have you adjusted the nozzle temp? I’ve been able to fix a lot of my issues like this just by raising the print temp up. Just out of curiosity, is that ABS?
The issue seems to appear along the outline of extrusion, there is no retraction at each 5mm of the outline, i think.
raising the temp make is even more pronounced. The part was printed in PLA but this also happens with ABS. The only filament it doesn’t happen with is ninjaFlex. I believe that is so because of the unique way ninjaFlex behave while its being extruded, in that the it creates a little pressure as its being melted and then extruded
I have done all of the things you mentioned. I will recheck the tightness of the printer. Honestly i think its a micro stepping issue, but i really don’t know much about it and haven’t been able to find much info through google searches
This was a calibration print. I set a print speed of 40 mm/s but it slows down to about 10 mm/s if the layer print time is below 30 sec. Also I can adjust the extrusion percentage lower but the i have a problem where the walls would be to thin and not printed at the desired thickness. I will keep trying
Thanks for you suggestions
it is a smooth rotation then its stops for a fraction of a sec. I don’t think i have noticed it jump.
Layer height is .25, .4 nozzle, 1.75mm filament, at 40 mm/s print speed(Slowed down to 10 mm/s if layer print time is under 60 sec), heatbed at 60 c, and hotend at 220 c (I use a B3 Pico and due to the design it has to run a bit hotter or else it jets jammed)
This object was PLA but also happens with ABS. Also i have used ninjaFlex and it prints out perfectly. I believe it does so becuse of the unique way ninjaFlex prints out and creates a small pressure in the melting chamber so it doen’t matter if the motor start and stops, as long as the delay is not to long.
Honestly I believe it might be a micro stepping issue in the Marlin Firmware but I have had a difficult time finding and info doing google searches.
Thanks!!!
Swap your extruder driver with another axis driver. Readjust pots. If ok, swap out your extruder. If you still have problem then your extruder is fine and pots fine.
What type of control board You could always swap stepper drivers from another axis to see if it changes anything
Switch the e and z before buying and see if it helps. E is most used and z is least used. If it resolves then you know before making any purchases.
Try reduing the layer height and increasing the extrusion width.
Sometimes the extrusion bead will whip around if there is too much space between the nozzle and the previous layer or the substrate. The whipping tends to be effected by that which it is being deposited on which would cause the pattern you are seeing. It is a sort of positive feedback loop where the phenomena perpetuates itself. Let me know if that helps!
Maybe a resonant frequency of the 4 springs that your build plate is mounted to, if you have a mendel prusa. Go to stiffer springs.
Not sure what happened here, but I hope this won’t be the last time you’re commenting here, @! It was a good input, so it must have been a mistake. Hope to see you around here soon :slight_smile:
1 month later
if you have a Persa Mendel like mine your Wobble might be Frame make sure your frame is true and all your Belts and Pulleys are tight and your Z axis is stable Dragging easy fix is more bolts holding the Z screw in place no oscillation.
