I have done all of the things you mentioned. I will recheck the tightness of the printer. Honestly i think its a micro stepping issue, but i really don’t know much about it and haven’t been able to find much info through google searches
I wish it was that simple. I have already made sure the bed is level and properly calibrated.
Thanks!!!
This was a calibration print. I set a print speed of 40 mm/s but it slows down to about 10 mm/s if the layer print time is below 30 sec. Also I can adjust the extrusion percentage lower but the i have a problem where the walls would be to thin and not printed at the desired thickness. I will keep trying
Thanks for you suggestions
it is a smooth rotation then its stops for a fraction of a sec. I don’t think i have noticed it jump.
Layer height is .25, .4 nozzle, 1.75mm filament, at 40 mm/s print speed(Slowed down to 10 mm/s if layer print time is under 60 sec), heatbed at 60 c, and hotend at 220 c (I use a B3 Pico and due to the design it has to run a bit hotter or else it jets jammed)
This object was PLA but also happens with ABS. Also i have used ninjaFlex and it prints out perfectly. I believe it does so becuse of the unique way ninjaFlex prints out and creates a small pressure in the melting chamber so it doen’t matter if the motor start and stops, as long as the delay is not to long.
Honestly I believe it might be a micro stepping issue in the Marlin Firmware but I have had a difficult time finding and info doing google searches.
Thanks!!!
This was my first instinct.
I read it and took you suggestion into account
Correct. No retraction in the making of this print
Extruder is nice and tight
I have moved the stepper pots both ways with no success and. PID autotune has been performed on the hotend
Thanks
What kind of machine is it?
Swap your extruder driver with another axis driver. Readjust pots. If ok, swap out your extruder. If you still have problem then your extruder is fine and pots fine.
What type of control board You could always swap stepper drivers from another axis to see if it changes anything
Switch the e and z before buying and see if it helps. E is most used and z is least used. If it resolves then you know before making any purchases.
FYI there is a patent on controlling flow with temperature ( by a big company… I think…)
Try reduing the layer height and increasing the extrusion width.
Sometimes the extrusion bead will whip around if there is too much space between the nozzle and the previous layer or the substrate. The whipping tends to be effected by that which it is being deposited on which would cause the pattern you are seeing. It is a sort of positive feedback loop where the phenomena perpetuates itself. Let me know if that helps!
Maybe a resonant frequency of the 4 springs that your build plate is mounted to, if you have a mendel prusa. Go to stiffer springs.
Not sure what happened here, but I hope this won’t be the last time you’re commenting here, @! It was a good input, so it must have been a mistake. Hope to see you around here soon
if you have a Persa Mendel like mine your Wobble might be Frame make sure your frame is true and all your Belts and Pulleys are tight and your Z axis is stable Dragging easy fix is more bolts holding the Z screw in place no oscillation.
You’re looking for something with a periodic oscillation and the extruder’s the most likely culprit. You can do a visual inspection by releasing the guidler and removing the filament so you can view the hobbed bolt/gear. Set the temp of the hot end and get the extruder to extrude 100mm (without filament). Watch the gearing for wobble and watch the hobbed bolt/gear for any unusual movement. The chances are you’re getting movement somewhere that isn’t rotational.
