Jun 2016
I am currently looking at buying a 3D printer. I think I will go for a DIY kit as it will allow me to fully understand how the 3D printer works and it will be easier to upgrade/change parts in the future. I like the reprap project for its community and the fact that it is open source.
Having that in mind plus the input from 3D hubs printer guide, I started to look at the Prusa Steel which seemed to have a pretty good ratio quality/price.
Here is/are my question(s):
First of all, I am particularly interested in having the biggest printing volume possible. I have read that the Prusa Stell can have a bed of 300X200 mm, do any of you have that printer and does the size diminish the quality of print (due to vibration or so…)?
As I am quite new in 3D printing, I am wondering how do I decide which hotend, driver, step motors I want on my printer in order to have the most precise print possible?
Finally (:p), if I decide to go though and buy this printer, what web site would you recommend? I have seen that most of them are in Spanish which can be a problem to me…
Any input/help is appreciated:)
Thanks,
Pierre
    Jun '16
    Jun '16
  • 21
  • 2.7k
  • 9
I would take a look at either the rostock max v2 or the the kossel pro. Both great quality and build volume for the price, the thing is that the rostock has a massive build volume and awesome community etc, but is known to be time consuming to assemble, kossel is newer and slightly smaller, better quality mass produced parts, nicer looking imo, but is a bit more expensive due to not having to upgrade anything so i would take a look at those! For the rostock the e3d hotend would help and the vibration dampers, i would get either printer from matterhackers. If i were you i would get a delta style machine like i have said with a 1.75mm bowden tube like the ones above because although all i have a dremel idea builder, from what i’ve heard, delta’s with 1.75mm bowden are really accurate, leveling is great, print time is fast, and build volume is crazy. Well those are my 2¢ and hopefully someone else can help you aswell!
Thank you for your reply.
I am looking at those right now. Seems that it is twice as expressive and the prusa (for a first printer I didn’t want to break the bank) but could consider it if the community agrees with you:)
Thanks for your reply.
Do you get good precision/surface finish with you printer and is there a kit available to buy? The toolson edition seems to me to be file to print the printer correct?
Yes, you would build the p3steel and then print the toolson upgrades. You can also get a cheap $200-$300 prusa kit and then upgrade it to a steel frame later.
What would be the benefit to buy a cheap prusa and then upgrade to steel frame? Cheaper than buying the steel frame kit directly?
What is your configuration regarding your motors, driver, board, hotend, and bed?
Cheap prusa would be cheap and quick. You would be up and running and printing. Then you upgrade to a steel frame later on. I have a cheap hictop, a steel frame a Rambo and toolson modifications on one. Two frames are en route and will have cheap ramps boards. I might throw the rumba on one. Each started as a different version of a cheap prusa with various upgrades. I might order a few more steel kits except I’m running out of space. With the fusion f400 and possibly a markforged coming in I would need to double my floor space.
If you’re not used to work with electronics and soldering one or two things, an Ultimaker Original + kit would be perfect. However, if you have a tight budget, I’d totally go for a Prusa i3 Steel (single frame if you will be moving it from one place to another). What I will never recommend you is to get a cheap prusa kit. Buy only quality parts (good nozzle, motors and electronics) and you will save money and time.
Thanks, I am an electronics engineer so shouldn’t be a problem. Do you have any recommendation on a good P3steel kit?
Hi Pierre,
Nice to hear you want to joint the 3d community.
Any of the Prusa i3 variant are a good choice to start, the P3Steel is maybe one of the best i3 around, take a look at the toolson edition in Thingiverse as said before.
The increase of the printing size on the i3 will cause a small decrease of the quality, but nothing to worry about IMHO. In any case, if you want to have the most accurate printer, go for the short version. The Y axis is probably theweakest point of the i3 and, increase the lenght will not help. You can also increase the smooth rods and linears bearings diametre on a later stage, designing and printing your own adaptors, which will give you a more solid structure. Btw, I got the long version, but I could not compare with the short so I can not tell you if there is a decrease of quality.
Anyway, as you will see, all the printer designs are compromissing quality on behaf of price in some way or another, however, you can get very decent prints with the i3. Don’t expect to be plug and play, I start getting decent printings after 1 month of having the printer operative (I am Electronics Engineer also), and still improving…
I thing the best advise I can get to you is to avoid any chinesse stuff regarding the mechanics (linear movement), avoid chinese LM8UU and stainless steel rods. Look for a known brand like Misumi or SKF for the linear bearings and use Hard Steel Chromed smooth rods with thight tolerance, try to source locally.
As you said most of the stores selling the P3Steel frame are from Spain, I live near Barcelona, so I buyed locally the frame, sorry I cannot help you here.
If you are really looking for big printing volume and good quality you can buy the Ultimaker 2+ extended or the BCN3D Sigma, ovbiously at a cost!!
You can also build your Ultimaker 2, look for Ultimaker 2 Tribute in Thingiverse, if you use a taller chasis you can get the volume of the extended also.
My last advise, use good quality filament like colorfabb, extrudr, our any other european or USA maker, advoid chinese stuff here also, the 3d printing is a sum of a lot things that can work well or not (including the filament quality) so as many things yu can leave out of the equation the more easy will be to locate the problems. When you have your printer working well, then you can explore other cheaper filaments if you want.
So move forward, look a lot, buy with some spares, start building and ENJOY!!!
Serious upgrades. I like the PEI surface and the upgraded extruder. The increased bed size is nice too. Of course, auto-levelling, better heat distribution on the bed - all good improvements.
Seems every week, there is a new “top of the wish list” for me.
Hi, thanks for the detailed reply. I agree with you and I now want to get the p3Steel and then later on upgrade to the toolson edition. Where did you buy your printer? As I said above, my researches have stop one this one: Welcome kitprinter3d.com - BlueHost.com 1 Since you appeared to have a 300mm printer, imagine that you had to print a rectangle with the following dimentions: 290-190-190 how much off would you thing the part would be? Just an approximation:) Also, are you happy with you surface finishing? At the end of the day, my goal wpuld be to print a matrix to then make carbon parts. The parts would be quite big=>that is why I need a big printer and I may have to assemble two prints to make one matrix=>that is why precision is really important…
Prusa i3’s have got to be the best style. They’re really good.
Anyway, a design client of mine sent me a cheap geeetech ripoff from eBay, cost £150. It worked really well out of the box and I’ve been upgrading it to even better since! Check my hub, that’s the printer I’m using and it does really well. The Marvin (though upside down in the pic) turned out really well.
Get one of those and print your own upgrades. It uses a GT2560 board so can easily be firmware upgraded.
PS if you want to upgrade to an E3D V6 hot end I’ve designed a nice little mount.
Indeed, customer support is a big plus for a first printer. Do you know if his new printer can be upgraded to a steel frame/toolson edition? Or is the frame bigger due to the bigger bed?
