I’m the owner of a Witbox 1 and now since today a Witbox 2… However, I set it up and tried a print and it was extremely noisy not the usual loudness of the Witbox 1 but more rattling and sounds that don’t sound like they’re meant to be there. Is anyone else having this issue or is anyone hearing these sounds on their Witbox 2?
the witbox 2 is noiser than the one. Probably in your case you also leveled the plate too tight or you should set correctly the offset. To set the offset follow the instruction in the packaging but consider to use a paper (as in the Witbox 1) to leave a minimum distance.
I have a Witbox 2 myself and I had some sound problems myself - but this sounds strange. Well in my case it was the hotend cooler fan. Mine was a bit loose and vibrated during the print. Since I fastend the screws a bit my W2 is silent.
Also Tip: When you print via a USB-Connection and have the Auto-Leveling feature on - switch the menu to Settings and leave it there. There is a strange behavior within the Marlin Firmware where the Printer is “thinking” between every turn wich results in a “stop and go” and finally result in “blobs” of plastic on the print. When you in the Settings Menu and just leave it there on say “lights” then the printer will run smoothly.
As a witbox2 owner I never encountered these sounds. Sometimes I had a similar sound, due to the printhead being to close to the glassplate. (a manual offset correction does the trick). But this is something else. Did you already put some oil on the sliders ? My guess would be a defecte ball bearing in the sliding mechanism or ball bearing in the motor. Try printing a straight line on the X axis ,compare that sound to a testprint of a line on the Y axis.
of course. i used Igus DryLin® RJ4JP that is the LM8UU equivalent. you will be surprised. they are incredibly silent and no luz is needed. they are self lubricating!
