Apr 2016
have you changed your retraction length and speed? changing mine has helped a lot
It’s doesn’t completely. It does allow you to slow and adjust settings as it prints. Most likely not the answer you need. You can find them for cheaper though anyway.
Try lowering your print speed to 50mm and 40mm for the outer perimeter. Temp to 205 and extrusion to .8. Also you need at least 3 walls perimeters sorry. I know it will take a while. The robo 3d stock fan is inadequate. You need a shroud to cool it off quick. Also, print an oiler if you haven’t already. Lower your travel settings to avoid layer banding. 0.1. Would bring out alot of detail. This print is designed specifically to crush your printers benchmarks. And the robo 3d and other moving bed designs don’t typically handle curved surfaces well do the inherent slop in the bed. Hop this helps. Happy printing!
Whoa, lot of info! Thank you. I will definitely try those setting.
And you’re right, it would seem attaching a better fan is something I will have to do soon.
What’s an “oiler”??
20 days later
Grimm, did you find a good solution? I have the same printer and am struggling with the Little Marvin as well. I appreciate all the tips in this thread and I’ve tried the retraction speed/length as mentioned below. I tried slowing from the default of 60 and 50mm/s for inside/outside perimeters to 40mm/s all around. So far it hasn’t made any(?) difference.
I’m trying to print two Marvin’s at once, as mentioned in this thread also…
I’m trying at 100 microns. I appreciate some of the feedback from those that are more well versed. I’m still learning what defects are caused by what problems!
I’m running mostly Hatchbox PLA filament. 210 degrees. BuildTak surface. Setting the bed temp to 30 degrees with .8 offset, doing the leveling before the temp raises so as to not ruin (another) BuildTak surface.
EDIT: using the MatterControl software with MatterSlice. Small custom g-code at the start to do the autolevel before heating the extruder.
Did you find a solid solution for getting a good Little Marvin? Thanks!
