Apr 2016
have you changed your retraction length and speed? changing mine has helped a lot
It’s doesn’t completely. It does allow you to slow and adjust settings as it prints. Most likely not the answer you need. You can find them for cheaper though anyway.
I don’t know why this hasn’t been posted yet, but turn the bed off (if using MatterControl, set the bed temp to 0). If you do not, Marvin will stay too hot for the duration of the print. This is mentioned in the instructions for Marvin.
Hi.
What slicer are you using?
have you changed any settings?
what layer height are you using?
have you done an extruder calibration setting?
many possibilities…
20 days later
Grimm, did you find a good solution? I have the same printer and am struggling with the Little Marvin as well. I appreciate all the tips in this thread and I’ve tried the retraction speed/length as mentioned below. I tried slowing from the default of 60 and 50mm/s for inside/outside perimeters to 40mm/s all around. So far it hasn’t made any(?) difference.
I’m trying to print two Marvin’s at once, as mentioned in this thread also…
I’m trying at 100 microns. I appreciate some of the feedback from those that are more well versed. I’m still learning what defects are caused by what problems!
I’m running mostly Hatchbox PLA filament. 210 degrees. BuildTak surface. Setting the bed temp to 30 degrees with .8 offset, doing the leveling before the temp raises so as to not ruin (another) BuildTak surface.
EDIT: using the MatterControl software with MatterSlice. Small custom g-code at the start to do the autolevel before heating the extruder.
Did you find a solid solution for getting a good Little Marvin? Thanks!
