Sep 2016
Hello,
We already called stratasys tech, but we are 700km from them and they won’t be able to come until October…
So here is the pic of vaccum tube and unfortunatelly there is material in it. Following the line, it doesn’t get to the pump in the front of the machine (it almost did, but now it is clean, see pic)
Now the printer is off, and I can’t run flush to let it off until october. I don’t know what to do…
You need to clean the vacuum tube going from head to the vacuum pump assembly. You may also clean the assembly itself, or replace the valves (just in case it’s impossible to clean). The problem usually comes from a clogged material or support material filter. It can also come from a clogged head: you need to print several times per week (even a small part), and also wipe the heads everyday with this technology.
Clean the tube again and remove the heads and clean them also, with pure IPA (no water mix). You can unclog the heads by using a syringe and force IPA through the nozzles: you have two holes and you need to close the other one with your finger. Use goggles and gloves!
Hello, thanks for your help! Can you help me with the process? Do I need any particular tool or device? Or just “unplug” the transparent tube from Head and pump? what should I use to empty de tube? pressured air? In our city we don’t have the spare parts from Humphrey Valves (I don’t know what models should I seek)
Hope you can help me,
Best!
Can you send me photos please??? :slight_smile:
Any recomendations when detaching tubes? Will I need to seal when assembing again?
Thanks!
It looks like the Material doesn´t reached your Pump (lucky You).
Its not deep inside the tube.Unplug both ends and use a wire to loosen the harden Part of resin in there.
The Blow Air from the other side (vacuumpump side) in it and it will clean out.
At last you flush the tube manual with alcohol and dry it with air.
If you need a Tutorial on that or photos let me know
a.roser@fabb-it.com
Finally tube from head to pump was clenaed out and empty (only air). Turned on again, but pressure keep low in 0.9. So we tested pumps and valves from “maintenance > actuators & sensors control”. It all seems to work ok. You can see model and support pump spin in the back. And Tac is heard when turning on waste pump and air and vaccum Valves. But the bad thing is that when turning on support pump, liquid begins to flow through transparent tube.!!
Any suggestions?? Thanks
11 months later
Hi Jay, I solved it applying WD40 in the axis a couple of days, ans it got back to spin normally and get the 6.0 pressure. They do not sell this spare part as far as I know
Hi protoserie,
Sorry for reply late, I didn’t got the notification, or I close it - will check it later.
So far, what I done is to shutdown my Objet and clean the print head continuously, until the material and support not dropping.
I didn’t clean the vacuum tube from head to pump, not yet.
And the pump company - Gardner Denver - just like you say, THOMAS 30030533-4V is special OEM part for selling to Stratasys only.
So, back to what you say…
Can you tell me or show me some images, which axis is need to spay WD40 a couple of days?
It will be very helpful to me.
Thanks again for your kind reply, and have a nice weekend.
Best,
Jay
Hi everyone,
So far, we can use WD-40 or something similar to let it back to work, but just in case if someone need to replace this miniature / micro drive “THOMAS 30030533-4V”, someday…
You can contact “FAULHABER”, which is the company producing this micro-motor, as you can check on the bottom information of THOMAS pump.
“FAULHABER”
“1525T012BRC”
“XY3306”
“1214”
attachment is the PDF of FAULHABER, check the last page (P.69) then you can find the information.
They should have worldwide reseller.
And it’s not that EXPENSIVE as THOMAS.
Good luck!
Jay
technical_information.pdf 43 (4.01 MB)
Thanks Jay for feedback, did you try to buy the pump? When I was looking for it, they did not sale this product.
Please tell your experience.
Best!
F
Hello @protoserie,
Yes, I wrote an e-mail hours ago, and I want to place an order.
Where did you ask? THOMAS or FAULHABER?
If they can sell this product, anyone want to buy?
I could buy some for spare parts and check if it’s possible to export.
you can also contact me by email.
info@lunglungdesign.com
or facebook > lunglungdesign
Best,
Jay
Hi @protoserie and everyone,
As I know, it’s possible to buy this micro motor only, and I will place an order for sure.
If someone wanna buy it together, just let me know.
It will take at least 10 weeks after the order be placed.
Best,
Jay
4 months later
Good printing and a happy 2018
Edgar from http://www.etchit.de 73
