We already called stratasys tech, but we are 700km from them and they won’t be able to come until October…
So here is the pic of vaccum tube and unfortunatelly there is material in it. Following the line, it doesn’t get to the pump in the front of the machine (it almost did, but now it is clean, see pic)
Now the printer is off, and I can’t run flush to let it off until october. I don’t know what to do…
You need to clean the vacuum tube going from head to the vacuum pump assembly. You may also clean the assembly itself, or replace the valves (just in case it’s impossible to clean). The problem usually comes from a clogged material or support material filter. It can also come from a clogged head: you need to print several times per week (even a small part), and also wipe the heads everyday with this technology.
Clean the tube again and remove the heads and clean them also, with pure IPA (no water mix). You can unclog the heads by using a syringe and force IPA through the nozzles: you have two holes and you need to close the other one with your finger. Use goggles and gloves!
Finally, the pump back to work.
I wrote down these steps and take some pictures on my blog.
but it seems that I can not allow to left link here. goo.gl/ydRi5a 185
So far, we can use WD-40 or something similar to let it back to work, but just in case if someone need to replace this miniature / micro drive “THOMAS 30030533-4V”, someday…
You can contact “FAULHABER”, which is the company producing this micro-motor, as you can check on the bottom information of THOMAS pump.
“FAULHABER”
“1525T012BRC”
“XY3306”
“1214”
attachment is the PDF of FAULHABER, check the last page (P.69) then you can find the information.
They should have worldwide reseller.
And it’s not that EXPENSIVE as THOMAS.
Good luck!
Hi @protoserie and everyone,
As I know, it’s possible to buy this micro motor only, and I will place an order for sure.
If someone wanna buy it together, just let me know.
It will take at least 10 weeks after the order be placed.
