Feb 2017
I have linked this many times but who is willing to understand the different belt designs please read and understand this blog entry:
http://blog.fabtotum.com/blog/2014/04/04/belts-and-stuff-experiences-to-share/ 424
It has all the information and calculations.
It will make clear how the XY motion is handled.
The only thing you have to design is the Z axis and this where a lot of printers are suffer. It has to be as stable as possible, if you grab the front of the table and move it up and down or right to left it should not flex/move at all. As any possible play of the table will catch up resonance of the XY motion during print and will show up in the print.
If you want to build a stable buildplate use 2 lead screws on the sides of the table and 2 or 4 linear rails(for bigger tables) to support it.
For me the cost is only for the v-slot, the smooth rods, pullys etc. I’ll rob the motors and electronics from my very first printer.
I was thinking of building a 500x500x500mm cube, obviously the print dimensions will be smaller probably in the region of 350x350x300mm by the time space is taken up for electronics and the actual motion gantry… 10mm GT2 belts are a sound idea.
That was a very useful link thanks :slight_smile: If I do build it I will probably use 4x 10mm smooth rod pillars to support the z axis motion probably also 2 trapezoidal / ball screw rods.
I just started ordering some parts for this printer build, I’ve ordered just enough V-Slot to make the outer frame … so I can get a feel for the V-slot and dimensions.
The V-Slot is actually fairly cheap however the Fixtures sure add up!! I’m going to have to have a good think about this … the way I was planning on doing it would require 7 Gantry Plates (the wheeled type) there £24 each… I think I’m going to have to design some Plastic parts to keep the Costs Down.
Ok, small tip, don’t bother with the special slot nuts, just use M5 square nuts. I don’t know about the plates but wanting more control over the process I’ve just finished printing all the fixtures. The D-Bot and C-Bot do this. I use 1.5mm walls, tops and bottoms and 40% infill. Go for the smaller V-slot wheels too, no point the extra bulk :slight_smile:
I found the square nuts recommended in the D-Bot BOM to be a PITA. They often stick when tightened down and you have to push the screws back in to break them loose. They are also marring the insides of the extrusions. I much prefer hammer T-nuts for ease of assembly and adjustment. Bangood sells the M5 Hammer Tnuts for $6.49/100 with free shipping. Not much more that the crappy square nuts.
The problem with most T-nuts, both twist lock and pre-assembly types is that they can bottom out on the raised channels in the D-Bot 3D printed parts before the part is securely fastened sometimes.
I’ve fixed that problem by remodeling all of the D-Bot parts to allow clearance for the T-nuts.
That’s handy to know I did buy a small qauntity of the proper drop in T nuts, they are actually pretty good. I also bought some square nuts there ok they do the job. I just ordered a load of gt2 pulleys from banggood never even thought to look for the nuts on there.
8 months later
15 days later
