I have Cubify Cube 3 and also Cubify Sense scanner. I’m pretty happy with both gadget but I have struggles with the softwares.
My biggest problem is, the printer software cannot read some, but only some, stl files which can be read by Cubify Sculpt. I use Catia to design my stuff and save as stl, and it cannot read the files generated by Catia, however it can read genuine files created by Sculp. And again, if I try open an stl file which created by Catia with Sculpt and resave, it doesn’t work either.
Does anyone else experience such problem?
Edit Post:
Well, thanks to everyone who put effort for my question, and here is where I get so long:
This problem first occured after 3.4 upgrade of the software but also it was a coincidence that I first time tried to print a Catia modified 3d scan file to print (I cut the arm scan into pieces to fit print volume)
I tried several different things I figured out by your helps, tried different stl generation processes no help, tried getting smaller slices so smaller files no help, and finally I tried to upload on website and Voi La! It just uploaded and synced the file perfectly and you can see what I got now.
So the problem is, Cubify is decided to steal every bit of printed documents in their cloud, even if you don’t want to share it anyone including the company. Now fraudulently have to give your designs to cloud system I suppose. It works like, if the sync time took so long, software says “cannot read” if you are logged out on software and the file is bigger than 1-1.5mb, it says “cannot read”.
So far, it seems we have a rip-off of ideas and designs here.
Well, I don’t have this exact experience but I’ll suggest you to open the STL files generated by Catia (that’s not opened directly) via Cubify.com 10, from My Shelf. Upload the file via My Shelf and update your shelf in cubify software to be visible there.
I don’t know why this is happening but since last version of software, it shows cannot read STL file.
Sorry for late response, I have no problem while printing. I have problem while loading .stl file to cubify software, so I can’t get a .cube3 file. However, I think I have find the reason. I’m posting as answer to root message.
