Hi!
Try this one, I think this is where I got it a couple of months ago.
And if you want to some of my adventures fighting with mine check here.
Try to run it as administrator
Hey guys, sorry for the nooby questions but how do you bleed the lines and clear out all the gunk? Im afraid I might have air in the spetum tank as printhead 0 is in overtemp but Im wanting to completely flush out each line. Any instructions or link on how to do this would be a huuuuuuuuge help
If the machine hasn’t had it done I would just replace all the lines. But to flush all you need to do is draw distilled water through using your purge tool.
Hi friend, i would like to recap my septums, but i dindt find a recap machine here at good price, i only find for 20 or 13mm, could you tell me where can i buy one??
best regards
nando
info@armadillotaller.com
Hi,I’m very new to 3D printing and this hub. I recently got an old spectrum z510 and after weeks of cleaning I finally got it going. but now I encountered an error that I don’t know how to fix. It keeps coming back with error 2303 axis error. I followed the instruction but nothing seem to work. Does anybody know a way to reset the machine to default (factory) values? Thanks
Could you tell me pls what did you get instead of original binder bottles and original connectors?
I have some info here: http://www.charlesrivermaker.com/wiki/index.php/Helpful\_parts\_%26\_sources\_for\_material
I ordered new connectors on amazon and hydration bags that I hung from an aluminum rack that I attached to the side of the machine. I installed ink filters like these: http://www.ebay.com/itm/USA-10pcs-80mm-Ink-Filter-5-Micron-Resistant-for-Solvent-Ink-Printers-/322482154016?hash=item4b156f2a20:g:H3YAAOSwYXVYx6K4 between the bags of binder and the machine.
It seems to be working pretty well so far.
Thank you so much!! You are in time and super helpful with the answer. Especially with the powder advice.
Could you please share a link on hp 11 print heads that are right for z510. And do they really need to be different color or it doesn’t matter if they are let’s say black color? How do they work?
Thank you in advance!!!
I
You need c4810a hp black only heads.
Thank you!!
Try www.3dcolors.pl - tested on 660pro and Z510. Works fine. Very cheep.
If any one is interested in testing some binders I would recommend www.3dcolors.pl :slight_smile:
“canadapowder” these guys have the same cheap prices and even cheaper on stuff like clear binder and head cleaner. Meanwhile they look more legit
I have zcorp 650 and it works perfectly , once i insert the ethernet cable and connect to the laptop the machine freez and i have to restart.
Hi!!
I’ve z510 for long time and I give some break using the printer. Now I’ve started it and LCD shows only the welcome note “high quality 3D printer”. Printer isn’t working and not even responding to keys.it would be great if anyone suggest what can be the issue?
