Aug 2016
I am looking at buying a PowerSpec 3d pro but have a few questions that I haven’t been able to find the answers to. First of all can the Pro model print PETG material? I have a few other printers that I have built but want something I can easily print from and don’t have to work on. I have read that the Pro is open source but does that mean I can use Slicer to slicer, save to as card and then directly print?
    Aug '16
    Aug '16
  • 5
  • 2.4k
  • 6
Unless the material is flexible(which evolves other considerations) you just need to worry about temperature. So the question for any material is, “does your extruder/bed get hot enough for whatever material you want to print?” This is easy to figure out.
-Jesse
I have a powerspec ultra. Pretty much the same as the pro. You can use pet-g with it along with other materials such as tpu, abs, and pla. I don’t recommend ninjaflex without a mod for the printer as ninjaflex is a very bendy material and can jam up the printer very easily.
A lot of slicers work with a power spec. I personally use Simplify3d as I am not fond of cura or some of the other free slicers available. Definitely did not like the software that comes with the printer either. Main reason I use simplify3d is because I like the controls especially when using both extruders to print.
I do recommend printing from the sd card. Printing via usb can sometime cause print issues. Have not had issues printing from the sd card.
I have two PowerSpec 3D Pro printers and have printed quite a few spools of PETG. The one upgrade you’ll want to consider is the micro-swiss all-metal nozzles. Without them, I ran into heat-creep issues which prevented me from printing long-running prints with PETG. If you decide to keep it stock, you’ll want to print and use some of these (thingiverse 492067).
However, if you upgrade the nozzles to micro-swiss, there’s no need for those. I routinely print PETG at 250c, 65c bed temp, on glass with a light coating of hair spray.
I have used MakerWare Desktop on the 3D Pro, but have since switched to Simplify3D and have printed over USB or SD card. I prefer SD cards for longer-running prints.
I enjoy the ultra as well, but it very much is a tinkerer’s printer. I currently do not have the money to purchase any slicers such as simplify3d, so I use the stock slicer. I’ve heard good things about Simplify3d, but can’t bring myself to buy it.
I also have the 3-D Pro and PETG prints just fine. I use BuildTac as on the bed which works great. Do not have to use glue or hairspray for any materials.
I use makerware desktop, which is free, and works just fine. You can customize settings to whatever you want, run from computer or save to SD card.
