Mar 2016
Hi Hubbers.
I want to start making lampshades on my FFCP, so I will need to be able to cut up my design for printing. But I would like the joins to feature in the design, rather than just be a smeared glue line…
So I suggestions?
I have found (not tried yet) the PuzzleCut on thingiverse which looks good. (PuzzleCut OpenSCAD Library by nothinglabs - Thingiverse 42)
Ideally, because my shades would be symmetrical it’s possible that I would only need one (or two) actual objects that connect together in a ring…
Am I asking too much?
Over to you…
Cris.
    Mar '16
    Mar '16
  • 3
  • 1.9k
  • 4
Hey Cris,
The jigsaw pieces are a great idea. Similarly to this if you don’t want glue lines, then you could make the design so it clips together. If it is symmetrical then this would be simple to design as you would only require one model, which can be printed multiple times. You could even have interlocking parts similar to a jigsaw, but could be hidden, so it would be in the design, like a dowel joint. If you don’t quite understand just ask and I may be able to find a picture which illustrates the concept. Good luck with the design. Could you please tell me how it goes as it sounds like an interesting project.
Hope this helps.
use you’re cad program to do it.
u can cut it up in anything you wont puzzle pieces, interlocking or …
anything you wont to
I don’t this applies very much to your lampshade, but the attached hinge design has worked well for us. See enclosed photo. Not very seemless for your application, but nice for parts that are taken apart and put back together often.
