May 2015
OKay checked this possiblity but i dont think its the issue, game em all a nice tighten though. The ultimaker robot did fairly well but a little drooping on the bottom below the body
Alrighty I’ll try to raise the temp but i thought someone stated it was too high in regards to the photo
Your definitely not to hot if your only at 205 on an ultimaker. That I can say for sure. Up the temp and see if it helps.
The simplest way would be to open it in solidworks or even blender and add a box 0.8 mm wide along the length, intersecting the model. I use Rhino for my modeling and it’s about 3 clicks of work there. Just add some geometry that you can cut off later to hold it down. Also, Cura has a very good line support
The temp should be between 190 and 210 for pla, if you’re printing slow, go for a lower temperature.
The infill overlap I was referring to was the infill and walls not touching and therefore giving you a bad part with no structure. I you use this feature at 60% it will give a better result since the infill will overlap the outside shell more and be more structurally sound.
205C as others has said is way to low.
You can also try to set the filament diameter a little lower (2,70/2,75/2,80mm), This will give you more extrusion.
You should get a nice print by reducing the speed of your print. Keep layer height at 0.15 and make changes to your materials : For PLA keep Temp 230 deg C, Build Plate: 80, Cooling Fan : 100%. Also, add supports, Touching Build Plate.
