Nov 2016
Hello all. I just purchased a Formbot TRex2 3D printer. I have been working with it all week trying to learn how to use it. On my third print, I had a small, very uncomplicated job. I was simply trying to print a rectangle 3"W x 8"L x 3/16"H to serve as a floor for a building model that I had 3D hubs print for me earlier. The edges did not come out square. From a side view, the printer made the edges at about a 45 degree angle, though this was not in the model. Any Idea what could cause this? I was using PLA at 230 degC.
    Nov '16
    Dec '16
  • 16
  • 15.1k
  • 3
Can we get some better pictures, sorry but cant really see the edge. Did you tried to print a normal cube to see how the edges are look like for that?
Also please share the STL file also to check.
Regards,
Tamas
Hello Tamas, thanks for responding. Yes below are some better pictures of the corners. No I didn’t print a test cube, that might be a good thing to do huh? I have made some test prints that have come out very nice. This one in particular however needed square edges.
I attached the stl file that I made from Sketchup. I created the g-code from Cura. I guess I expected the machine to print square. I am using PLA at
230 degC and 50mm/sec, .0.2 Layer height. My bed is heated to 57 DegC.
tan_bldg_floor_1.stl 1 (684 Bytes)
Hi Frank!
The stl file looks fine, its just a simple rectangle no errors in it.
Was the print stick well to the print surface at all corners(bed leveling)? As this looks like the corners lifted /curled up during print and this caused the issue, so check the bed level again, and watch it during print if its lift up or not.
I would suggest to print a smaller test cube, to check how the printer prints walls.
Here is 20mm cube to test you can scale it up from 20mm to 40mm http://www.thingiverse.com/thing:1366547 79
Its a ringing test also so it will show mechanical resonance near the holes if there is any on your printer.
Here is also a good troubleshoot guide for print errors:
https://www.simplify3d.com/support/print-quality-troubleshooting/ 132
I would also lower the print temperature to 200-210C for PLA the 230 looks way too much. Bed can 70C and in Cura you can set it to print a brim(platform adhesion part, usually by default its print 20 lines around, in the expert setting reduce it to 6)
Regards,
Tamas
I can’t quite see exactly the problem with the edges from the pics. I do see is a ton of wobble and ringing artifacts. Usually that means belts are not right enough, the print head may not be secure enough, or something else is being allowed to move around when it shouldn’t. You can also try slowing down the acceleration to 300 and jerk to 1 and see if that helps.
If you are using Cura btw, you may have the “Make overhangs printable” option turned on which would round off edges.
13 days later
Hi Tamas;
Very helpful, thanks for that. My apologies, I have no training in this. Been reading, but I have no formal training. I’ve been modeling for some years, but new to 3D printing, I wanted to try to bring my models to life. I purchased a printer, but soon found out it’s not like an inkjet! I am an engineer these past 30 years, I’ve worked with our power plant automation, I thought I would pick this up easily, but this is a totally different thing. I might need to take some classes at the community college. I’ve only had two successful prints so far out of all my attempts. I had been trying to print a model I made for my wife for a jewelry display. After some hours the print would slip. Later, the Y driver failed. I replaced it and the print still slipped. I found the driver voltage had to be set. I set the voltage and the slipping appears to be better, but the prints were very rough. The guides were dirty. I cleaned them and greased them and it helped a great deal. I’ve been trying to print a successful test cube but haven’t been able to complete one yet. The extruder keeps contacting the piece after about 1.5 hours of printing. Maybe the Z-hop and combing settings will help. I lowered the nozzle another 0.1mm at Formbot’s suggestion. They keep telling me the way to get the piece to stick to the bed is not with temperature but with Z offset height. They seem to be correct it does help, but they recommend 55 DEGC bed temperature and that doesn’t seem to be warm enough. The piece seems to hold better between 60-70 which is what 3D hubs troubleshooting guide recommends. Problem is I’m learning this thing one problem at a time as they come up. I tried to print last night, only to find that the end stop switch fell apart, and the table wouldn’t complete its level routine. So I purchased some replacement switches from Makerbot. Should be here in a couple of days and I’ll install and try again.
I attached my advanced settings tab, sorry about that I should have checked. Getting older, I need to double check myself. Tonight I’ll look into the calibration software.
You have been a very helpful resource! Thank you so much.
Hi Frank!
First:
There is one big mistake in this configuration: Initial layer line width % is 300 !!! so it means for the first layer you try to extrude 3X times the amount of filament. Please set it back to 100.
Also the initial layer thickens(first layer height) I recommend 0.2mm.
You retraction values should be tweaked a little : speed to 50mm/s and distance to 4mm.
Its a pleasure to help you out! Yes these machines can be quite frustrating in the beginning, but don’t worry you will deal with the issues, with your engineering background i confident that you will solve it.
Witch endstop is broken? The Z-axis? You can make the printer work without it if you like.
What I would like to offer you is to have conversation via skype, so we can walk through the slicer settings and will give you some advise regarding the printer.
Please drop me an email to tpalagyi82 (at) gmail.com if you are interested.
I know your situation when I have started 3D printing back in 2013 I had similar problems as you are facing now. Not a single successful print for 3 weeks… but back in that time I really had nobody to ask for help, so I have figured out myself it took me a lot of time.
What I always say to new guys setting up 3D printers(supported more than 50 printer builds during the years…) is I sucked so much with these machines during the past years , that you really don’t need to, use my knowledge and experience to deal with the starter issues.
Regards,
Tamas
Tamas, yes I would like to take you up on the Skype connection. I am located in WV, USA. New York time or eastern standard time. I’m still working, I’m available between 5:00PM to 12:00AM, or early morning 5:AM-6:30AM. If needs be I can take a day off work. It is the Y axis end stop switch that failed. The slicer settings I have are what Formbot recommended. I really would like to understand what they mean. I’ll adjust my settings as you suggest.
Got your mail, I will make reply to you, and we will continue there.
Have a great day!
T.
