Jul 2015
We here at Expose Yourself are exited to announce the arrival of our BigRep ONE.2 3D printer with a 1 m³ working volume (27 times the volume of a large desktop 3D printer). This opens a gateway to a new dimension in 3D printing and 3D manufacturing. There are virtually no limits to your creativity, from human scale robot parts to full-dimensional sculptural artworks, anything is possible.
The BigRep ONE.2 can print in PLA, ABS, Copolymere, Laywood, Laybrick, PC, PA, and TPE. We look forward to working with local makers and businesses to produce some of the most mind blowing 3D prints in the world!
I was wondering if anyone had any suggestions on any cool samples we can try to print on this beast.
Thank you, Its a fun machine! The vase is the larges so far, I am about 14 hours into a dragon head from thingyverse. Its going to be about 38" wide by 15" high (2500 cm³) in volume. We are always open to ideas!
Marvin is awesome! He has completed printing and is in the finishing process, we will be sure to post the final product!
People are always moved by seeing a print of something they recognize. Maybe try props from well known movies, comics or video games. There’s plenty to search for on thingiverse and the other model sites.
Thank you for the suggestion, that’s a great idea!
It actually has 2. The one installed on the left is a 1,0mm nozzle and on the right is a 0,5mm nozzle.
Oh wow, this is so awesome! What are the printing settings you used for these prints? I mean how do they differ from regular ol’ printers?
You may also find some of the cool models @derKarsten suggested on @RamPrasad. Pretty cool to capture a museum or significant piece and then reproduce it as a 3DP on the other end of the world, where people won’t get to see the original.
Welcome, prints look good for that size. High detail at this scale is usually not practical(very long print time) so I’m curious to know, what size nozzles and layer height are you guys printing in?
NASA is right up my alley! I have been playing with this Saturn V model. That Woolly Mammoth model is amazing, that would be impressive.
Thank you for all of the help!
Well we are very new to the 3D printing world so we are learning very quickly how much “time” plays a factor. I have been using a 1,0mm nozzle with a layer thickness of 0.5mm a extrusion width of 0.8mm and a skin thickness of 1.6mm. I use the 0.5mm for smaller objects with the settings set to layer thickness of 0.25mm a extrusion width of 0.5mm and a skin thickness of 1mm. I am open to any suggestions as far as settings.
Well to be honest im not sure how this machine differs from the standard printers, this is the first 3D printer we have used, I can say that the set-up and training on this machine was far simpler than I thought.
Thank you for the links, that is a very interesting concept. It would be nice to see NASA release a 3D model of the solar system with all of the data they have collected over the years. Printing the surface textures of different planets would be pretty cool.
I think your best bet is to stick with that setup if you intend on taking advantage of the full dimensions. The big nozzles and thick layers might limit detail/resolution but with geometric designs(like the beautiful crystal you printed) dimensional accuracy is still perfect and should yield great prints. I use .1mm nozzles with .1mm layers on my smaller printer if I need high detail but using that set up on anything larger than a few cm^3 starts to get ludicrous. My largest printer is 25.4cm X 25.4cm X 26.0cm. Use anywhere up to .8mm nozzle on one extruder for infill/support any anywhere from .2-.5mm on the other. I have considered putting together a large format (looks like so much fun) but I haven’t had the need that would justify. Good luck and enjoy!
-Jesse
For practical purpose large format printers usually have much larger nozzles and run with thicker layers (unless you want to spend days or more on a print). So it’s literately like zooming in on the model. For example, using a 1.0mm nozzle means any detail in the x/y axis smaller than 1.0mm is not possible without putting a smaller nozzle and therefor drastically increasing print time(resolution in z axis depends on layer height). While small detail isn’t possible this shouldn’t have any effect on dimensional accuracy or quality of prints that don’t involve tiny detail. This also means there is little room for error because small imperfections are also “zoomed in”. A hiccup on a print with .1mm layers can easily go unnoticed without a magnifying glass but with the large format any imperfection is going to be much more noticeable. Looks like these guys have it dialed in pretty good!
-Jesse
I have been playing with speed vs detail for a few days now(that crystal took 16 hours) with , with the dragon currently printing the time lost seems really to be in the supports. We are printing him completely hollow at about 38" long and the support structure its generated is a bit excessive. I am trying to get the support settings right so that I can shave hours off my print times. The large format is fun and surprisingly simple to work with!
Thank you for all of the help. Ill be sure to continue posting our creations.
I have been playing with speed vs detail for a few days now (that crystal took 16 hours with the infill at 50%) , with the dragon currently printing the time lost seems really to be in the supports. We are printing him completely hollow at about 38" long and the support structure its generated is a bit excessive. I am trying to get the support settings right so that I can shave hours off my print times. The large format is fun and surprisingly simple to work with!
He is 12" tall!
Ill post him as soon as hes ready!
That would be amazing! I would love that. Let me know if the height maps are available. We are planning on printing a scale model of the Eiffel Tower at 80" high!
Congratulations on your new purchase. I am the US reseller of BigRep GmbH.
Contact me if you need anything.
Thank you.
Wow that’s awesome! You could collaborate with the guys (@Tiesdenh) next to 3D hubs that are trying to make the kids bike from 3D printing. You could almost print the entire bike in one!
3D Fuel is a sustainable 3D Printer filament manufacturing company in Meridian, Mississippi. We are offering a high discount on our out of spec filament. We have 92 spools of white PLA filament in a tolerance of +/- .08 for $15 a spool and 411 spools of black PLA filament in a tolerance of +/- .08 for $15 a spool. This does not mean the entire spool is out of spec. There are parts of the spool with perfect +/- .03 tolerances throughout. Please contact Jorge Cornejo at if interested!
Hey @Amoniqu3, in this community, we really appreciate people’s input that is related to the topic at hand and it’s helpful, in one way or another, to the maker starting the thread. Your type of comments, promotional and out of sync, are most likely to annoy the people here, rather than bring any added value to them. I’ve noticed this is not the only exact comment you’ve posted today in different threads, which is why we’ll make sure to erase all of them. Please refrain from these type of comments moving forward and consider this your first warning. Cheers
Awesome. So well painted. How much material for one of these big boys?
They’re over 40,000 euros aren’t they?
We have an 800x800x800mm printer ( and we built it ourselves ) here at 3D Seed if anyones interested.
We also use the E3D Volcano nozzles with a 1mm layer height so it’s FAST as well.
We also sell them for half the cost of the BigRep :slight_smile:
We also sell larger 3d Printers as we manufacture VSlot here in Spain (from Openbuilds)
The maximum size we can engineer can use the 6 metre lengths so anyone want to print a house/car etc ?
12 months later
8 months later
