Aug 2015
Can someone print me a print that is 80 CM X 30 CM X 30 CM with a lot of details?
vergeten de eenheden bij te zetten, kan jij en print van 80cm doen ?
Wow, 80cm is really huge. I’m finishing 57cm/28cm delta this month, and next month 45x45x52 cartesian 3 colors printer, but man 80cm is a lot :slight_smile: You should consider, if not done already, splitting it in two. Not just a simple cut, but as you mention lot of details, then with the right soft, you could follow some of these details to do an ‘invisible cut’. That will require some time though :-). Good luck anyway. Feel free to post your stl to satisfy our curiosity :wink:
The stl needs to be handled with discretion, so if you want i can send you the stl, and maybe you can print it in piece?
We got 30X30X30 printer. If you may be interrested!
As I said one comment under:
We got 30X30X30
Cutting your part could do the job…
Send me the file if you wish!
