Try turning the bed heat off and set the extruder temp to 180. Also, make sure the fan is at 100% while printing.
Skip to main content
Thanks for the info. I didn’t think it was really bridging but still learning!
I did print 2 at a time but go the same basic result. I have it pretty good for no support (thinking no support was a requirement for test). I have cooling maxed out and print as low as 500mm/min but back up to 1000mm/min seems to get the same result so sped up for time sake!
I’ll give your support suggestions a try to learn and see how it goes.
I think we are gaining on this sucker!
I’ll give it a shot. Thanks.
