Thanks James,
There is the option to print with doors open and a small desk fan blowing in there (the same as I do for PLA printing on this printer, having lowered temps with the software mod). I could also try a lower extrusion temp too. Also the print head has a selector for directing more air onto the print as it comes out which I presume will cool it quicker too, probably a good idea for Marv as he is so small.
I will give thrm all a try tomorrow and report back, thanks again.
You would get better answers over on the Up forums. http://pp3dp.com/forum
The problem with the Up is the software was designed to work with support so it does a poor job with bridging because it doesn’t know to print a little faster/cooler when bridging. Your biggest issue here is being too hot for your filament. If you search the Up forums there is a software hack to allow you to lower the printing temp. Alternately, if you prefer a hardware solution you can build my hardware mod for under $10 http://www.thingiverse.com/thing:528396
Once you have a temp mod you can print with or without support just like it is Up genuine filament.
While you don’t have a temp mod having the fan door open (handle in the up position) will also help but usually I don’t like to print that way for ABS as it will make bigger things than Marvin warp. Also printing on Fast will help that bridging but you will need to the fan open because those layers may not cool fast enough otherwise.
couldn’t wait till tomorrow !!
So printed with the OEM white, door open, lid open and fan switch on and a USB fan blasting in (same as I do PLA) results phenomenal…well at least I think so :slight_smile: I will now try the same with the non OEM silver and temp mod down to 230c and see if the outcome is as good
Your Marvin looks amazing! What fill setup, layer thickness and printing speed have you used?
I ordered black ABS from Ink Filament (http://www.3d-printerstore.ch/3D-Filament/3D-Filament-1-75-mm/ABS-Filament-1-75mm:::49\_51\_55.html?MODsid=vvs7thm41ne63s1l5gm5ih3ns2) and it worked really well without any change of the printer setup, even with door closed.
I’ve never tried PLA so far. I’m working with Mac so I can’t use the mod, so sad.
Let me know.
It was the UP abs filament, 0.2, standard temp settings, minimum fill, support base only, with raft add support for 10 degrees or more 3 surface layers.
i just found this youtube channel which seems great for material reviews so now in my favourites, he uses the up mini…
maybe you can get a cheap old laptop off ebay to use PC and hack for a very small amount…
Or just do a hardware mod for temp instead like a linked above. There is no point leaving the doors open for ABS as it doesn’t have a crazy low softening point like PLA. A little bit of fan coming through the wind barrier is enough if it needs help to firm up.
I looked at both hardware and software temp solutions, opted for the software one due to the level of customisation between layers too, the reason I printed with door open was because I have modded by board from the standard 50c to the 100c(but generally achieve 85-90c) so need to disperse that extra heat on small prints, I just have a USB fan that blows in and up and out the top (lid open) I modded the board because larger prints were warping at the edges with my up.
The mod for the hotter bed is to solder one of these in parallel to the one on the bottom of the hot plate, 5 min job Amazon.co.uk
The suggestion to do the hardware mod was in addition to your response to the Mac user.
Good you’ve done the bed heater mod - it’s essential but you do not need to open the doors. Your issue is not because the area around the print was too hot it is because the print was being printed too hot and not cooler fast enough. This is what the wind barrier is for. For ABS you want the surrounds as hot as possible… it does’t matter too much for your small print but it will for others. For PLA, you want the opposite with the surrounds and bed as cool as possible. Chances are you will struggle with PLA on any longer prints on a Mini anyway without serious cooling direct into the extruder.
I am just trying to help you out as an experienced Up user. I’ve only done nearly a thousand prints on my Ups (kid you not), helped a few thousand Up users with their print issues … if you want to take the advice it’s up to you.
I think your black marv looks spot on !
I have now run the OEM white Marv as uploaded lastnight and today the silver Marv with extra cooling and tweaking temperatures a bit, I’m really happy with them. I am as we speak printing off an orange PLA version again temperatures tweaked through the s/w mod and a bit of rapeseed oil with the filament load(I have read it keeps PLA sweet in the Up! box, I did have an initial bit of clunking when it started but not since on the 20min print in fine mode all fans)
Hi Simon,
thanks for the help it is much appreciated, certainly didn’t mean to come across as disrespectful. I appreciate you taking the time to reply and help :slight_smile:
Thanks again :slight_smile:
You guys really should take the discussion to the PP3DP forum as there is a much better body of knowledge over there. 3DHubs tends to be full of old wives tales of other new users who suggest things like oiling up PLA to get it to work. At least on the PP3DP forums one of the experience users will jump in and tell you when stuff is a bad idea. I don’t get on their much myself any more as I got a little tired of the same questions for 3 years and i think I’ve done my time over there as the biggest poster … but it’s a good community, worth throwing your questions rather than here where you’ll get as much bad advice as good.
No offence taken … just trying to shortcut the convo by explaining I do have a decent chunk of experience. Have fun with your Mini.
Roller.
I have tried the PP3DP forums but they are rarely used, so many questions go unanswered and have found it’s weeks before anyone does reply, also a lot of the material on there is old, that said I found the software mod there so am happy and there is some useful stuff there. :-)) At least I got a reply here within a few hours that helped me resolve my problem, again, thanks to you and everyone else for the input.
I’m just onto my second PLA print with the temps modded, started extruding no problem…I feel like a kid at Christmas, my desk looks like it has been overtaken by minion/marvin invasion… :slight_smile:
I did check there yesterday before here for an answer to my marvin problem but couldn’t find an answer.
Oh that’s a shame. Maybe that’s because the three top posters and assistants there have all move to Zortrax printers. The body of knowledge there is very good though but the search is useless… use google search and direct it to the forum. Pretty much everything you would ask including the top post has been asked many hundreds of time before. I was going to do up a Wiki with a FAQ but we never managed to get around to it and for the first time my Up sits idle while my reprap and Zortrax get all the attention.
On PLA you shouldn’t have a problem until you get on to longer prints. Some Ups (Minis included) have more trouble than others simply because some extruder steppers run hotter which is the source of all the issues with PLA once you aren’t printing too close to the bed. On that latter point try to be sure you don’t get more than a click or too on PLA. These are the sound of missed steps due to back pressure … with PLA they will rip a bite out of the side of the filament and you have a jam. If you jam too many times clean out the extruder gear as the PLA powder stuck in the teeth acts as a lubricant making future issues more likely. Don’t ever use lubes or oils like suggested earlier … over the long term it will give you nothing but hassles and it’s a pain to recover from.
If your longer PLA prints are jamming google for the mods by Drew Petitclerc … he has a blower mod using a fishtanks pump which has pretty much a 100% success rate. Easier are some extra ducting and fans around the extruder to keep it cooler. The extruder in my Mini was beyond this help and I had to go to fish tank pumps until I made mod to drive the extruder gear through a belt to stop the thermal connection to the stepper. Anyway, Drew’s mods are on PP3DP forum and on thingiverse - the cooler and the drive gear pressure mod are the most useful. There are newer and easier alternatives but they are the best solutions for all cases.
cool thanks for the tips, I think you should do that wiki page :slight_smile: I actually have an old pump laying around from one of those old tubes you know you used to put the water in a glass vertical tube and plastic fish and it blew air in to make the plastic fish rise and sink… I might look at putting it to good use using the mods you suggest. :slight_smile:
well here is the orange PLA (faberdashery) the first one didn’t print too well using standard UP temperatures, I changed the print temp to 230, the under extruding problem seems to have gone now but its just not quite as sharp on the bottom of Marvs helpmeet, its the only place I notice it really, grey and white are ABS ,PLA orange in the middle, welcome any thoughts on sharpening up the edge of the helmet in the PLA
You should eb able to go lower on that temp - 230C is more an ABS temp. Faberdashery stuff is usually a better grade of PLA so it would be on the higher end, like 210C. Just listen for a jam towards the first few minutes so you can catch it early if it’s too low and save yourself having to clean out PLA dust form the jam.
Other than that, front and top open of course and a fan direct on the print (wind barrier fan is not enough). If you can’t direct it well on to the print insulate/screen your hotend and nozzle as best you can. Forcing the hotend to work harder can result in more heat working up in to the top of the extruder.
If I may offer my experience with acetone vapor smoothing for ABS.
I find that using only vapor, the detail of the print is damaged too much by the time the required smooth finish is achieved. To overcome this, I do my treatment as a 2 part process :
I use step 1 to strengthen the part ( using the acetone to better join the layers ), and then step 2 to make it look good and glossy.
Note : I do not sand any part until after step 1. I think that if you sand the part, you are clogging the small gaps between layers with dust and limiting how well the acetone can work.
so step 1 : to strengthen the part, I either dip the entire part in acetone, or if it is larger I use a 1cm wide paintbrush and paint on the acetone. After each I shake / blow off the excess acetone.
After step 1, the part will have a white / light patchy stain over most parts, and you’ll think you have ruined your print - do not worry - you have not.
Leave it for 1 hour for the acetone to evaporate and the ABS to harden. You can then do any sanding that you want.
Step 2 is to give the part the gloss shine - do a hot acetone vapor treatment and you’ll see the discoloration disappear within a few seconds. Vapor treatment only takes about 5 to 10 seconds.
My hot acetone vapor treatment takes me about 4 minutes in total from start to glossy print.
I use an old cheap tin cooking pot, about 2-3 liter capacity. A large deep metal coffee tin would work just as well.
I rinse the pot with a little water, pour out the water, and then heat the pot on an outdoors gas cooker ( bbq ).
Heat until the last of the water has boiled away. This means that the pot is now hot.
Use a small jar to measure about 30ml acetone - keep it covered and away from the gas flame.
Turn off the gas - this is an important step !!
Now pour the acetone in to the pot and put on the lid.
Wait about 20 - 30 seconds for the acetone to vaporize.
Slide off the lid and insert your print ( hanging from a wire or cotton thread ).
You can watch the color return and the gloss appear in a few seconds.
Remove the part and hang to dry for 15 minutes.
Done.
Thanks. I am going to give this a try. I never thought to use acetone to strengthen the layer bond. New tool for the 3D printing tool box.
Thanks for the feedback. I watched a few YouTube clips to learn the process. I have never dipped or had any physical contact with the acetone with my ventures. I use an old electric hotplate (camping one) and an old coffee peculator glass pot. I heat the glass pot gently and then add some acetone (not much at all), I only heat it enough to see the vapours running down the outside of the pot (not coming out the top) and then hang the print in there for about 30 seconds and then take out to dry, the finish is as per glossy marv above, I have not seen any loss in detail as yet, though I accept sharp straight edges may become slightly rounded depending on the level of exposure
This was the video I found dead good http://prometheusrising.net/2013/04/01/prhi-acetone-treatment-for-abs-3d-printer-parts-video/
the idea of acetone and any naked flames is danger danger, I did read about a couple of guys burning their garage down trying it this way…
I hear your concern, and that’s why I said : Turn off the gas - this is an important step !!
In fact, your electric hotplate could be just as dangerous as a naked gas flame.
Acetone vapor is heavier than air, so any vapor that gets out your container is going to sink / drop.
Many electrical appliances have some sort of thermostat controlled mechanical switch that regulates the temperature, and even a small spark internally could ignite the vapor.
When I first started experimenting with acetone vapor, I was using a deep ceramic pot slow cooker which took about 20 minutes to warm up, and even then I was very careful to turn off and unplug the mains before adding the acetone. The ceramic pot held the heat for a long time and that was enough to vaporize the acetone.
My use of a tin pot on a gas stove is the exact same thing, except the pot is heated in about 60 seconds, instead of 20 minutes. In both cases, the power / flame / ignition source is removed before adding the acetone.
I admit that the tin pot does cool faster than the ceramic pot, but I am usually not treating more than 1 or 2 pieces at a time, and the speed of using the gas cooker is a big benefit to an impatient person like me.
