created
Nov '17last reply
Nov '17- 6
- 1.9k
like
Skip to main content
Hi there, it looks like your nozzle is a little too far from the bed and it’s causing the prints to not adhere. I’d recommend re-leveling with the bed a bit higher. You should be able to push a plain piece of paper between the nozzle and bed with some resistance.
Also, if you’re using PLA your heated bed should be set around 55-65c. I can’t tell if you have this set or not, but just wanted to mention it.
Best,
Maddie - 3D Hubs
Unfortunately the bed on this printer sometimes comes warped from the factory, which is why the middle of your bed may be off level from the rest. I’d recommend picking up a piece of borosilicate glass, and placing that over the current bed surface.
