Oct 2015
Hey guys,
If you’re fan of Low-Poly designs, you’ll probably know Flowalistik 2 already. His portfolio consists of the gorgeous Pokemon and Retro Gaming Characters - and now finally a Low-Poly Marvin as well.
We’re extremely happy to share these beautiful design exclusives with all of you.
Happy printing!
Make sure to share pictures of your printing results :wink:
Pro-tip: Just click the title to order your print!
A wearable print to pimp your Halloween Swag :
Low-Poly Devil Marvin Mask 2
Enjoy this awesome low-poly devil Mask of our very own Marvin, just in time for Halloween. I highly recommend printing it in Glow In The Dark, simply because it looks epic. By the way - it’s me wearing the mask here above.
Also funny detail, the string to attach the max is Ninja Flex filament :wink:
Printed on a LeapFrog Creatr HS with Glow in the Dark Filament from @b
No support required, just printed it upside down with a raft, all good ! Files available on YouMagine 5 and @Cults as well!
Low-Poly Marvin 5
Very nice version of Marvin, the low poly give him a retro look that I’m really diggin !
Printed on BeeTheFirst in 0,05mm layer height and 20% infill. Small defect on the base of the feet as the most sharp eyed will notice :wink: Files available on YouMagine 2 and @Cults as well!
In addition to the Low-Poly Marvin - we also have two Halloween versions for you guys.
Low-Poly Frankenstein Marvin
Marvin got a scary remake for Halloween, sharp teeth and wide forehead, with some nuts on the side of his neck, Frankenstein style !
Printed with FaberDashery Glow in the Dark filament, using DeeGreen printer, just Epic !
Low-Poly Devil Marvin 7
This is my personal Favorite, Low poly and Devil-skull head are just perfect for a Halloween Marvin !
Printed with the same filament and printer as the Frankenstein Marvin.
A nice Gif with those two under light and in the dark :
What do you guys think? :slight_smile:
Victor
    Oct '15
    Jan '16
  • 13
  • 3.2k
  • 8
Thanks 3D Hubs for everything! I must admit that the original Marvin looks great, but I always found the model to be a little bit difficult to print (50% because of the size, 50% because of the keychain part). I tried to solve all the problems I had encountered when printing all the Marvins I’ve printed so far. We could say the Marvin I’ve designed has the graphics of a Playstation 1 model!
I guess something about 5/6 hours print !
Don’t remember exactly the settings but nothing crazy:
Temp : 200°C
Speed : 6000 mm/min (a bit too fast even for Creatr “HS”)
Infill : 20% Planning to make a new One with 100% for a better glow effect
Only important thing is to print it upside down with a big raft so it don’t fall under it’s own weight :wink:
Also scaling it a little bit to make it smaller.
How practical is it to wear it? My concerns are aimed to the weight issue you raised :wink:
