Looking for a larger volume 3d printer. The build volume is 410mm x 410mm x 115 mm in height. A conical shroud. Most 3d printers are very limited in size output
thanks
created
Apr '15last reply
May '15- 16
- 2.0k
likes
thanks
Hi !
I am not living in Los Angeles and my printer not completely fits your part but i could divide in three pieces .Depending on the material you want it is very easy to glue these parts together, if you want ABS it would be possible to “melt” the part together by dissolving the edges with some acetone, this is also commonly used to make stronger abs prints, because the layers get bonded together.
-Marius
You could search for printers such as Big Rap, or Pivot Maker. These are large machines
That’s a big shroud what kind of materal because I don’t have a heated bed.
can you send a 3d print of it?
I am in the LA area but would have to slice into two pieces and glue them together.
Afternoon Jake,
I made a molded proto-type out of silicone Rubber, not cost effective though.
Looking for a plyable material such as nylon, for most PLA are harder and if struck can become sharp shards
Its conical and hollow in the center
I’m flexible on materials. The key ingredient is they are not rigid hard. Also a material that can be colored is needed
If you think you can print a 410mm conical shroud let me know. The inside cavity does not have material. The vanes that make up the shroud are 1/8" wide by 3/8" long and are spaced with a 1/2" open span between them creating a grid
If you have capabilities let me know. I can send you a jpg now and STL with all dimensions if you can accomplish the work
thanks for getting back to me
Don
Thanks but i’m looking for a single seamless unit. I’d thought of a notched fit but then it requires assembly thus raising unit costs
Do you fear the cost increasement of printing with some connector notches ?
The price increasement is minimal, it will make a much bigger difference how much the Hub of your choise charges for each cm³ printed. Or is there any point that i am missing, that makes it necessary to print this in one part.
-Marius
Tell you what…I’ll print it in pieces and if you don’t like it you don’t buy it.
Hi, visit Original’s hub, we have a large printer in los Angeles that satisfies your needs.
re:3d.com has a huge print volume… this machine works very well.
No thank you, appreciate the offer, but this is a single unit and don’t need experiments
What resolution or quality can this print at? What materials can it print with?
Hi Don, thanks for the input! Just a heads up I moderated your email and phone number out. Moving forward, would you please use a link to your Hub profile as means of contact? Cheers
Brand Name:J GROUP ROBOTICS
Model Number:P0010
Place of Origin:India
Packaging Details:3D Printer - 1 quantity 3D Printing Filament - 1 quantity Charger - 1 Quantity Warranty Card valid upto six months. Shipping, Duties & Taxes extraDelivery Detail:3 WEEKS
Please stop spamming your advertisement for your 3d printer in threads, where noone asks for a new printer. In this case the thread creator is looking for price estimations for his project. Cheers, Marius Breuer
