Jul 2017
Going to need a lot more info.
Slicer, printer, material, temps, speeds etc.
Thought I posted that sorry.
cura
maker select v2
pla
210 print 65 bed
I’ll double check print speeds tonight but should be
60 print
50 first layer
travel I believe is 80.
I would say heat is the issue. 210 is a little high for most PLA. Run a test and see how it does at 200. Also you can drop the bed temp after the first layer. I go to 55-60 depending on how the print stays stuck.
Slow the print down. Try it out at 2400mm/min to start. Slowing a print can fix or improve a lot of issues.
Does this printer have the parts cooling fan? If not then you might try some additional cooling.
This probably wont help but is the heat bed to hot or are your retraction settings incorect. that is the only thing i could think of but hopefully it helps
I’ll try that thank you.
For bed leveling I like to make it so the filament is about 1/2 squished. So it’ll be flat but not so flat where it’s impossible to scrape. Is that what you do as well?
Sounds ok. You really want to look at the overall first layer and see how it looks to you.
I turned down to 200 and 60 and it got bumpy Ina few areas then peeled up in the back side which was close to the edge of the bed.
