my print keeps warping and the corners look melted. I tried to mess with the cooling to fix the warping and I also tried to mess with temp to fix the melting look but neither work. Anyone have ideas?
I would say heat is the issue. 210 is a little high for most PLA. Run a test and see how it does at 200. Also you can drop the bed temp after the first layer. I go to 55-60 depending on how the print stays stuck.
Slow the print down. Try it out at 2400mm/min to start. Slowing a print can fix or improve a lot of issues.
Does this printer have the parts cooling fan? If not then you might try some additional cooling.
This probably wont help but is the heat bed to hot or are your retraction settings incorect. that is the only thing i could think of but hopefully it helps
For bed leveling I like to make it so the filament is about 1/2 squished. So it’ll be flat but not so flat where it’s impossible to scrape. Is that what you do as well?
