Jan 2016
Ok, two things, if it didn’t crash when you did that its not your offsets! And secondly, if Update Firmware is greyed out in Makerware then its because you already have the latest version. But you can check which version on the printer itself, either by just turning it off and on and you will see the firmware version when it boots on the display, or in the info and settings menu. If its already 7.5 then your ok there.
Ok so what’s the problem? Most likely the same problem i had on mine when i got it. Your getting an interference issue from the stepper motor wiring which is falsing the stop switches. This is REALLY common, and it used to come up 2-3 times a week on the Makerbot forums and Google Groups when everyone was getting Rep 1’s.
Here’s how to fix it… From the X axis motor you will see the stepper motor and the stop switch wiring loops up and goes across the top and down the front right corner through the hole in the bottom panel in that corner. You need to unplug the X axis stepper motor wiring, the multi color wiring as the stop switch cable should just be a black cable. Pull it up through the bottom from that hole and pull it out of the retainers except the last one that it loops down from, then re-route that stepper wire cable across the top to the back right corner but keep it away from the Y axis motor pulley and belt and go down the back right corner and plug it back in.
If you want to just test this quickly unplug the X axis cable and pull it up from the front right corner hole and just hang it out the right side and plug it back in underneath then test that it can home and print. The X axis stepper motor wiring interferes with the stop switch wiring and in some cases it will also cause issues with the unshielded ribbon cable to the front panel, but putting it in the back right corner its routed far enough away from everything it doesn’t cause issues.
His problem isn’t firmware now though, cause if he positions the carriage on the X and Y stops and then starts a print he doesn’t get crashing, meaning the offsets are correct and its not going to far.
The key to troubleshooting this is in his last reply to me is that if he manually homes the X and Y it works, which means its not getting a correct homing. Also when he homes the axes the X doesn’t return fully home.
On the Rep 1 this is a very common problem caused by the stepper motor wiring coupling to the stop switch wiring since everything is unshielded wiring. Moving the X-Axis stepper motor wiring from the front right corner to the back right corner is the common solution and was even being suggested by Makerbot support at one time.
On some i have even gone so far as to make a shielded stop switch cable, which also stops this problem dead. To do that i take the braid from a bad thermocouple and pull out the thermocouple and use it to make a shielded cable for the stop switch.
Ok I will try the rewiring later tonight. I am also having other issues though.
I set the heater settings to 215, and it is constantly going up to 230 when i am preheating.
For example, if I do load/unload, it heats up to 230, then waits to go back down to around 215 and it will begin unloading/loading. I never had that happen before all this shenaniganry.
Also, when I try to do a print, the heat actually goes DOWN while printing. I saw it go down to like 189 during the print (still set at 215), and then it starts jamming up, maybe because the filament is less viscous.
Apparently, I am very good at keeping myself from printing correctly.
Ok for the preheating, go to Info and Settings then Preheat Settings, are those numbers set correctly?
Does it go to 230 and stop? No errors? If it overshoots too far and its correctly reading the temperature it would pop up that there is a temp problem. But it sounds like its just hitting a preset temp.
The temp going down while printing could be a number of factors, cold room, air movement it cant keep up with etc, but it could also be a temp reading issue yet with the thermocouple.
If moving the stepper motor wiring doesn’t fix the homing on the X axis you could still have a bad or intermittent X-stop cable for the X axis switch. I have had that happen before as well, it causes really weird intermittent issues, but from what you described it sounds like the problems i had with the interference issue.
Won’t know until you try one step at a time!
I got one print out at a an average of about 220 degrees or so in PLA, at it was all warped and everything, but at least it finished wih no carriage jam or nozzle jam. It was a bit more consistent with the temperature on that particular print. I still think I may have even damaged this thermocouple because it jumps around in temperature like 10+ degrees on the temp screen with no transitions. I can’t actually believe that the actual temperature is jumping around like that. I have a source for a $20 thermocouple, so I’m going to try that. Still had no luck with the firmware update. I tried 20+ times last night and I got the same error. I wonder if it’s just fruitless to update it on this particular board.
What are you getting for an error when trying to update the firmware?
Which version of firmware is in it now?
Also on the thermocouple a new one is probably a good idea but also i would check to make sure its insulated at the heater block. If you have a multimeter set it to the continuity test and unplug the thermocouple from the mainboard and check for continuity from the mainboard end to the heater block its attached to, and check both wires. Continuity from the heater block to the thermocouple can cause some weirdness as well due to static charges and such, its also a good way to blow up the chip for the thermocouple. At the very least if you don’t have a meter to check it make sure the end of the thermocouple is wrapped in a layer of Kapton tape, the gold tape that you use on the print bed, and then it should be electrically isolated. If your thermocouple has a ring terminal on it and its not the factory one i would also wrap a layer of kapton tape around the ring terminal so it covers it completely then pierce a hole in the tape in the center of the ring terminal for the mounting screw and reinstall. A lot of the cheap thermocouples i have bought off eBay with ring terminals were just crimping onto the end of the thermocouple and were not insulated. The way it should be done is the thermocouple is glued into the ring terminal with non conductive thermal adhesive. But its hard to find good ones that were done right!
My stock Makerbot thermocouples are just a bare end wrapped in kapton tape and pinched under the washer on the mounting screw, they still work great, i guess they were a lot better quality then most.
Hello,
I attached some images of my current firmware. As for an error it simply says “upgrade failed” and says I can try again. So I do, and it is starting to get frustrating!
I also attached images of my wiring layout (which seems wrong, but I couldn’t really fit it another way. It Does twist the thermocouple wire quite a bit, so I am wondering if that part is now busted.
In addition, I also attached an image of how when i’m printing, the nozzle/heaterblock is smoking because the temperature is going up to 230-something while I print. BTW I did wrap the thermocouple completely in the kapton tape I have, and there has been no improvement.
ALSO, when I pause a print, and restart it, it does not continue the print in the same spot. So that tells me something other than the heat is still off.
Ok if i had to guess, its the 7.7 you have in there. I know guys will try and say different on here, but i tried 7.7 on my Rep 1 and it was NOTHING but problems. You also mentioned that it won’t pause and continue in the same spot, i had similar issues with 7.7, it was just totally unreliable, missing steps, jittery stepper motors, lots of weird movements, it was a friggin NIGHTMARE. So i went back to Makerbot’s 7.5 firmware and everything just smoothed right out.
Your going to be burning off stuff at that temp, so no surprise its smoking. At this point i think a replacement thermocouple would be a good test to rule it out, however, the fact that its set to 215 and its at like 234 it should be tripping the overheat warning, normally what i would see if they overshoot that badly is a message that says something like “my temp readings are failing please check the wiring” etc. Apparently the 7.7 firmware doesn’t have any safety cutoffs to it?
Ok for the firmware problem, use replicatorG and get the factory 7.5 firmware, then before you try it, open just Makerbot Desktop and click on Services then Stop Background Services, confirm anything that pops up, then Close Makerbot Desktop. Then open RepG and try the firmware upgrade and select the 7.5 version of stock makerbot firmware for the rep 1. Now the trick is, getting the reset button press on the back at JUST the right time. Sometimes i find if you click the reset button on the printer with one hand while clicking the button on the software with the other hand at the same time works, sometimes you have to tap reset on the printer then click the button a second or so after, it varies. This is why i modified my mainboard, it involves adding a capacitor to the motherboard to enable the auto reset so you don’t have to click the button on the back anymore when doing a firmware upgrade.
I did some digging through my backups tonight and i found my copy of WinBotTool and a hex file of the 7.5 makerbot firmware, i had to do a recovery on one a while back. If your still having issues with this let me know, i can upload these files to my webserver and send you a link. The WinBotTool is VERY easy to use, all you have to do is stop the background services in Makerware, close it, then run the WinBotTool select the firmware file, and it will tell you to turn the printer off, click ok on the box that is up, then turn the printer back on, and it starts writing the firmware. I just tested it today on another printer i’m working on, took the update the first try.
That sounds like a great idea! I tried again another 15 times, I feel like I am going insane with this to be honest. I even looked into new printers today. But I would be willing to try the WinBotTool route if you are willing to send me the link.
If you want to email the link, email it to jeffreyyounger@gmail.com
Let me know!
Thanks
8 months later
I’ve done this as well, a couple things to add. You can desolder the power connector from your old Makerbot board and solder it into the GeeeTech board, just desolder and remove the screw terminal block they put on them, then you can continue using the stock power supply without chopping any wires or worrying about polarity etc.
The power switch lines up perfectly, no mods needed there. I didn’t make any hole for the micro sd card slot to be used, really no reason to as its not needed for anything, in fact most of us that have done this repair removed the micro sd slot from the board to prevent it becoming a noise ingress source to the processor since its close to the Z-axis and where most of the wiring is going out the back to the steppers on the extruders. Other then that and the stepper driver mods its pretty much a plug and play replacement.
You can also desolder the stepper motor screw terminals off the Geeetech board and replace them with the original headers off the Makerbot board so you don’t need to chop your stepper motor cables. I just modified the board rather then having to modify any of the wiring, all the parts on the Makerbot board will drop right into the Geeetech board, they just went with more universal screw terminal blocks to keep it cheap.
2 years later
I would offer to look at your old board to see if it can be repaired.
Are you still repair Mightyboards?
I have two Rep1 - one is working quite good but one is broken.
I have here also two Mightyboards rev. E which seem to have the broken/popped Voltage regulator.
Thanks,
Alex
