Nov 2016
Do I need to put the data in manually, or is there a way to download the data in Cura?
As I have tried many times now to manually adjust Cura with the configuration data Wasp gave with the printer, with the help of the Guida Cura PDF. But It it is not working. Probably because I don’t understand the data yet, and the PDF Guida Cura explanation is all in Italian.
Hi, you can upload the setting in Cura. Unzip he file, from cura you open the ‘file’ menu, click on ‘Open rpofile’ and then point to the ‘Configurazioni_Delta 2040.ini’ in the folder you unzipped before. What release of Cura you’re running?
Hi, I am running Cura 13.06.5. Thats the one Wasp gave me. So I kept that version and did not upgrade it.
I suggest you update to version 14.12.1 care, and load settings machine as I told you
Hi all!
Just got our WASP 2040 Turbo (white). Had issues using the supplied filament, with it causing the entire printer to lock up and forcing a power cycle. Installed Monoprice PLA and all is good now. Anyone else have an issue?
Also, am using the default WASP ini file with Cura. Anyone have a good ini file or better settings to use? I am very happy with the quality of the print, but worried that the WASP didn’t detect filament flow error.
Anyone else out there with a WASP 2040 Turbo?
1 month later
Hello All,
I just receved delivery of my 2040 yesterday, hoping it’ll prove a good investement, I’m new to using these machines and would like to know where to find the best
support/tutorials for it, any suggestions?
~The problem I’m having is trying to print the honey comb braclet test file supplied by WASP, the Makerbot Gnome seems to print fine (I stopped the test at 35%) but
this “Honeycomb braclet” fails once it begins the first link sections, they never seem to connect or stay connected to the base support structure it prints first, why might that be?
Theres a video of this print timelasped by another user here : - YouTube 7
For ref my print fails at around 12 secs in this video, the half the bits don’t stick to base. I’m using the same supplied material and havn’t changed any of the settings apart from bed levelling.
Any and all info appreciated,
Myrza, how did you get on? …useful tutorials for using the Delta WASP 2040?
Thanks,
Dara.
9 months later
Thank you!
