hi!!
tell me what you want to know, if you send me some screenshots of settings can i help you!!
but, i don’t know about Clay material!!
see yah!!
hi!!
see yah!!
hi, where are you from? i’m a reseller delta wasp and i know cura very well…
Hi there @Amil_Malik, good things happen for those clicking on the user icon https://www.3dhubs.com/users/myrza\_de\_muynck
Hi Myrza, i print with DeltaWASP and PowerWASP for 2 years, but I live in Italy, in Turin…
If you have some question, please ask, I will try to answer, but I’m sorry, I’m too far for a workshop.
Best compliments for the choice, you bought a great machine!
All the best
Enrico
Hi, I’va a DeltaWsp since February and works very well.
Do you have any specific problem with it?
Hi Myrza
The easiest is to know, what you like to print and in which material. Just feel free to send an object and we can shortly explain you how you can get the best result.
I think in the end it all comes down to getting your hands dirty and asking for help when needed.
Is someone here willing to do share the printing process on their Wasp, to walk @ through it? Cheers
Thank you all for your response! I am very happy you would like to help. :)
Maybe the best thing to do is to contact you when i do my next printing session.
And ask specific questions.
I have trouble understanding how to level the print bed the right way.
But I will contact you when i start printing and can communicate exactly what i’m doing.
Hello myrza, yes sure! Tell me what you need. I work in wasp
However for leveling just go to the menu, prepare, manual leveling, and move the position of the extruder 1,2,3 and finally 0. To adjust the plan once positioned the extruder into the desired position (eg position 1 ), you have to turn the adjustment wheel at the bottom. Turning it to the right lower floor, while lifting it to the left. To find out if you have to raise or lower, you can pass a sheet of paper between the extruder and the floor. The sheet must pass quite accurate.
Thank you. The levelling works if I print out he sample gcode files Wasp gave to me on the SD card. But if I want to print out other files from my laptop using Cura, the bed is either too high or low. I think I have to figure out my Cura settings. They are probably not accurate. But I am not sure how to do it.
Yes the problem is in the configuration. Try to download and install this file. (is the configuration for your printer) and tell me if is ok personalfab.it - This website is for sale! - 3d print Resources and Information.
Thank you! I will try it.
Thank you!
