Hi guys , I have the same printer and the same problem did not send me the frimware and and installed several but the printer goes crazy and does not run the engine extruder , please send me the frimware must go my mail is deivison90@hotmail .com
I have emailed you the firmware, just be sure to measure your max z height and change that value in the configuration.h tab to match
exactly the same probleme with my kossel anycubic that i just build yesterday pleas send me your firmware Quantumzblue@gmail.com Thank you a lot
Here is a link to the copy of Repetier I am using with my Anycubic Kossel, Hope it helps someone…
https://drive.google.com/folderview?id=0B76dpYLQ7rqAZEpRMERLNHA5T3c&usp=sharing
could someone send me your firmware settings that is working for you please?
get me your email address and I will send you along the firmware for the anycubic with some simple instructions
Thank you very much! I watched your video and my lcd is the same as yours.
my email address is verygreatful@hotmail.com
I never got your email yet…hoping to hear from you soon. my email address is in last message. Thanks again. I appreciate any help!
Hello Jeanie I emailed you the firmware and a couple of things to do with it
Hi SummersideGuy,
I too would like this firmware and config as well as the setup info. If you could send to kidispo@hotmail.com that would be most appreciated.
Thanks,
Ki.
i Sent you the firmware. If you do not have the Arduino SDK on your system make sure you have the latest Arduino SDK installed.
Once that is installed you can click on the marlin file in the marlin folder when you unzip it and it will load into the Arduino SDK. There will be a bunch of tabs, the tab to refine your zheight and pretty much all of your other parameters is configuration.h. you plug your printer into your pc. In the arduino SDK under tools select your board it is Atmega2560 then under port select your com port your printer is connected to. You can now click the circle with the arrow on it just under the edit button to upload the firmware to your printer
Thanks again. LCD is great but still cannot get the printer to go to home because the arms veer off into the side and almost hits the belts if I do not use the emergency stop.
Can you email me a pic of your wiring to your ramps board, sounds like you may have something wired backwards. I can take a look and advise you. It could be a end stop switch or a motor
Looks like this is what I’m struggling with as well. Can you please send me the files and anymore info you may have? grant.sullivan@rocketmail.com
I’m getting the same LCD screen error that you are. My steppers work fine just my LCD screen won’t display anything besides the two white lines like your’s did.
What did you do to solve this problem? Was it just a firmware problem?
One of two issues, if you don’t have the smartlcd enabled in your configuration.h settings then enable it LCD2004. Or your contrast could be too high, there is a small adjustment screw on the back of your lcd panel near the sd card slot that will lower or raise your contrast
Ok I’ll check the configuation.h settings for the LCD2004. My contrast seems to be ok.
Thanks,
when I get home I will check the marlin files and let you know exactly which it is
