Sep 2016
Yeah, the common wisdom seems to be that you should keep your layer height at 80% or less of nozzle diameter. I personally never go above 50%, even on infill, for reasons above.
It’s a setting that is stored on the board itself. If your board uses EEPROM(and has it enabled) it’s as simple as sending a few gcode commands. If not you would have to re-flash the firmware. Which firmware does your machine use?
I mostly use Marlin and have zero sailfish experience but it looks like the gcode is the same. “M501” will return all the current settings stored on the EEPROM.
FIRST THING you should do is take a screen shot of these setting so you have them as a back up/reference.
You should see the lines:
Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
In the example above, the jerk is 20. To change it to 15 you would send “M205 X15” and then “M500” to save the changes. If you do not send “M500” after entering any setting, it will not be stored. You should then send another “M501” to verify the changes were made and are correct(a decimal in the wrong place can be a disaster). The jerk settings are kind of subtle unless you make extreme changes(don’t do this). If 10 or 15 doesn’t fix anything don’t try going lower. Regardless, you just got access to some stuff you didn’t know was there. Enjoy.
Thanks, I’ll check this out and I need to research this setting since I don’t know what it is for or what it does.
How about acceleration settings? I don’t need this thing lightning fast but smooth and steady with out using the “granny” gear!!
More to learn!!
I was just looking at stuff and reading up and I think I can change this stuff via Replicator G. I did use that to fix a lighting issue and change a couple other minor things on the advice of FFCP support.
Does this seem right? I can post a screen shot this evening of what I am seeing.
Thanks for the help guys!
You have to be careful comparing certain M commands that work in marlin that do not work in Sailfish, and vice versa.
So with marlin, you can easily recompile the firmware, and there are a few GUI ways to do this.
Sailfish, which I personally like, some of the slicer software allows you to do change parameters.
Sailfish has accelleration built into its firmware, and messing with the firmware settings messes with some complicated formulas that provide excellent prints from Sailfish.
The simple 1D kinematic equation for distance including jerk is:
s = vi*t + (1/2)*ai*(t^2) + (1/6)*j*(t^3)
where s = distance traveled, vi = initial velocity, ai = initial acceleration, j = jerk (i.e. rate of change of acceleration), and t = time
You can change “jerk” settings with sailfish. The key is that this is often a choice of last resort, because it can be difficult to change back to defaults without reflashing the software.
S3d does not have jerk setttings, and I recommend getting dialed in with S3d, but if you really want to know all there is to do, and expand your control, you can mess with firmware settings. Jerk is explained in the sailfish manual at "4.3.2 Maximum Speed Changes " under firmware settings. In effect, it will do the same thing though-slow down your printing.
Thanks. I guess I better leave it alone. It just seems odd I can’t print this small barrel faster than 1000mm/min. The one large enough to hold pens and pencils will take over four hours to print!
I am going to draw one myself to see if it is any better.
It has been a good learning experience.
Follow up: I went ahead and changed the X and Y max speed change from 15 to 10 and the X from 10 to 0. I haven’t tried 5 on the X-Y since I got the impression that may be to low. If you guys think it would be ok then I could and see.
The changes do seem to really smooth out the printer without a noticeable speed sacrifice. It didn’t seem to do anything major for the ringing issue but may have helped a bit. A print at 2000mm/min is pretty good.
One thing I haven’t tried yet to see if it helps is printing more shell layers. I am at 2 and maybe it doesn’t like that. I am not sure of the actual wall thickness since it is just an STL. However when I made my own sample I gave it a wall thickness divisible by the nozzle width I have set (.4) and that didn’t make any difference. Anyway, I’ve learned a bunch more so thanks again!!
