Sep 2016
Thanks. I guess I better leave it alone. It just seems odd I can’t print this small barrel faster than 1000mm/min. The one large enough to hold pens and pencils will take over four hours to print!
I am going to draw one myself to see if it is any better.
It has been a good learning experience.
Jerk (not the actual physics term, which is the second derivative of velocity) has to do with how fast an axis makes a direction change. It should only affect your overall speed unless you make significant changes but small changes could have a big impact on the type of issues you are dealing with. Don’t mess with it if you are not comfortable.
-Jesse
Thanks, I am comfortable with it, plenty of experience with BIOS’s and firmware (computers) but don’t want to go making changes if it is not really a good idea or hard yo undo!!
I think Perry indicated a re-flash my be needed to undo. If it is simply running the flashprint and doing the firmware upgrade again then no problem!
I am going to post a pic from RepG of the acceleration page and see what you guys think and advise!
I see a button for “fine print” and it seem to change only the first two items “max acceleration” settings down to 2000.
I would be ok with going in the direction of “fine print” settings as long as it doesn’t bring the overall speed to a crawl!!
Thanks, I really do appreciate all of the help and advice. I have found that I am able to offer simple advice now to those who are newer at this than I am because guys like you guys take the time to help me understand this whole process better and improve my knowledge and prints.
Looks like “max speed change” is the equivalent of “jerk” on marlin but I would defer to @perry_1 on this because he has more experience with the specific firmware/software you are using.
For the most part, forums like this and endless tinkering got me to where I am. I’ve tried to offer as much info as I could on this thread specifically because of your previous contributions in the forum. Happy to help someone who helps!
-Jesse
BTW, those option are the EEPROM I was talking about. Your software just has a nice interface for you to change them. Does “RepG” display the gcode that is being sent to the machine? If so you should notice that when you change those settings it’s actually just sending the gcode that I listed above. Sorry if that caused confusion.
No confusion. I was thinking it would be easier for me to make the changes using the RepG interface.
I think it does display the G-Code but I didn’t look at it.
Yes, Rep G has one function anymore. To change/update firmware.
When I spoke of having to reflash, I spoke mostly of the once you get all the settings all mucked up, you might have to reflash.
Acceleration in sailfish, is explained here http://www.sailfishfirmware.com/doc/sailfish.pdf section 4.3.
If you haven’t already, this is a great manual on the firmware, and explains a lot. Good bedtime reading.
