Aug 2015
My printer is printing in the back left corner. Dont know what to do.
Slicer: Slic3r
Firmware: 7.7 Sailfish
Fileformat: .x3g
    Aug '15
    Sep '15
  • 1
    reply
  • 961
Did this start to happen after you flashed Sailfish?
If that is the case you might double check that you’ve restored the correct offset
http://www.sailfishfirmware.com/doc/install-installing.html#x34-840006.3.1 6
Does the same behavior occur if you use MakerWare? This is to rule out firmware configuration issues and more slicer related.
Finally in Slic3r there is a settings that allow you to define the bed shape (view screenshot) on this settings the bed origin corner is define.
Hope that help Best of luck :slight_smile:
