Oct 2016
I’m also looking for the default settings for my Delta wasp turbo 2040.
I cannot seem to upload the files for the machine settings.
Are they written down somewhere?
I also have trouble loading to the sd card from cura
    Oct '16
    Oct '16
  • 6
  • 2.6k
  • 3
Hi James,
if you mean the settings for cura, you can download a tutarial il english from my site here:
http://www.cosmo3d.it/downloads.html 83
Otherwise, tell me what kind of settings you need.
What happens to your SD card? Anyway you can copy the GCODE files as an USB key.
All the best
Enrico
Thanks Enrico!
I’ll take a look tomorrow and see, is there a way to look at settings from the existing files on the sd card from delta wasp?
Jim
Hi Jim,
I hope that my tutorial will be useful.
If you need, you can load the setting from a GCode file.
If you open the menu ‘File’ from the Cura menubar, you find the ‘load profile from GCode’ command.
This command do what you’re looking for.
Have a nice sunday and happy printing.
Enrico
PS: If you want, place a like and/or follow my Facebook page at: Redirecting... 6. :wink:
Thank you this was the easy part.
I was wondering if you have a default list for the raft/brim/speeds/ etc?
I’ll look at the sample gcode files to see what they are set at
the fist prints were coming out great but didn’t stay attached to the plate.
I don’t have the glass base I was given the stick glue but think I’ll clean up and get some hairspray tomorrow.
thanks again! My Italian is abysmal.
Hi, I will complete the tutorial as soon as possible.
If you have the stainless steel print bed, it could be easier tho keep the objects attached.
I never used the glue. I use the airspray every time. When you go to buy it, keep in mind that the cheaper you buy, the better it paste.
Avoid to buy too high quality hair spray. I don’t know the brands you have in USA, so I have no suggestion to give you, but you can ask to somenone in your area.
Pay attention to bed levelling: too high distance from printing bed and nozzle on first layer can cause detachments.
Anyway: If you print PLA you can add from 5 to 15 brim loops. I use RAFT very rarely, never used with PLA.
If you print ABS or other more difficult filaments, use 15-20 loops of brim and more spray on the base.
There are no fixed rules, it depends from type of filament, temperatures, fan settings, shape of the object, etc.
For PLA and PET-G keep the fan settings 30-60%. For ABS, Nylon, ecc keep fan settings 10-40%.
However, the life of 3D printers dedicated people to is a life of experiments: each release should be analyzed individually.
I hope this will help. All the best. Enrico
