Jan 2016
Hey guys!
Now I’m pretty new at this… I got my printer last year, and it’s been a learning curve every day… But I’d say I’ve gotten pretty good at it!
I recently(Finally) got a few rolls of filament and wanted to try out multi-material printing.
No what happens is, from the Makerbot Software. I loaded the Dual-Hilbert Cube Example. It sent it to the printer, and the printer started heating up. I preheated it, so I didn’t notice at first. But it only printed with the right extruder. When it cooled down too much, I could hear the stepper churning away at the filament, but nothing was coming out of the nozzle.
I then tried making a .x3d file. Loaded it onto the SD card(After a huge fight with the update of the Makerbot software, had to roll back to a previous version) and it did exactly the same…
Left extruder didn’t heat up.
I have PLA in the left and ABS in the right…
Also… Anyone else having trouble with the new Makerbot software?
It keeps telling me “Printing failed” and “File no longer exists” and when I click on “Preview” the bed is just empty, and this is with the preloaded examples…
No left prints, it really only wants to heat up the right extruder.
About the problem with the left extruder, there is a bug in the current version of Makerware, when you use a duplicated profile.
The left extruder on my Flashforge only heats up when I choose one of the standard profiles (low/standard/high) and change it’s settings.
I really hope they fix this in the next version :confused:
Ok! That makes sense, since I duplicated the profile to change the values for the PLA…
You say it should work on an original? If I repurpose, say, low for this jop…?
check if in the printer settings the left extruder is enabled, if I’m not wrong , info and settings-general settings-toolcount->DUAL , after the upgrade firmware mine resetted to one, after u set dual the monitor should show left and right exstruder, I hope is somethin simple like mine :slight_smile:
Hey! Thanks! The problem was with the Makerbot software. Apparently there was a glitch…
Thanks anyway!
23 days later
Looks like they fixed the bug in 3.9.1 :slight_smile: “Left extruder not heating when printing files generated using custom profiles”
I’m so glad I read this, it fixed my issue too, with the left not printing. Saved me alot of time reading. Thanks a million!
10 days later
I’ve got 3.91 on my Mac and the left extruder won’t heat. In the setup screens the left extruder keeps losing it’s settings. This last time I tried it kept the settings, but when I tried to print, the left extruder never heats. Any ideas?
Thanks.
**Update**
I think it’s working now. When you hover the cursor over the dual extruder settings, it gives a pop-up that tells you 0 and 1 are the numbers to use for right and left. But… I found another MB doc that indicates 1 and 2 are the numbers you use (1 is right, 2 is left). I set it at 1 and it appears to have worked.
**Update 2**
Nope. It’s definitely 0 and 1 to assign the extruders, but the software is ignoring 0 when I use it.
