Oct 2017
My Creator Pro always worked well. Recently, when I try to start a print, the bed raises, the carriage moves to the front-left (as usual), and then moves back toward the right-rear (as viewed from the front). But just before it would hit the back microswitch and the left microswitch, it plays a little tune and just stops.
When I go to the control panel, I get the option to UN-PAUSE. It then heats up and when it starts to print, it displays the message"
“entering PAUSE P-stop triggered”
But I’m doing nothing that should cause it to enter PAUSE. When I try to resume the print, I get the same message. Does anyone know what is going on?
    Oct '17
    Nov '17
  • 6
  • 1.3k
  • 4
Are you printing from your computer or sd card? Which slicer do you use?
Time to start messing with your endstops and endstop cables to see if you can figure out which one has a short…
Try printing with SD card and check if you still having the same issues. FFCP has known issues when printing via USB
10 days later
Printing from computer. It doesn’t matter which slicer. All act the same - Replicator G, older versions of Makerware, etc.
