Jul 2016
You would definitely be able to get to 260 degrees no problem. Just make sure the motherboard can handle such a load. Try asking the company selling the 80w upgrade if the mighty board on the flashforge creator pro can handle the current draw for it. I’m thinking of upgrading my hot ends in the future too because of the lack of heating with metal nozzles. If you do end up upgrading to the 80W would you mind posting to update me on wether it solved your problem or not. I want to see if the upgrade works for you and if it does I’ll probably join you on the upgrade.
The heat shielding kapton tape is intact so the heat should be kept in the hot end which is good. The wires to the heating element look fine too so it’s gotta be a defective heating element on the right extruder. Unless anyone else has any other idea’s I think it’s pretty much case closed and pick up a replacement hot end for the right extruder and it should solve your problem.
After thinking about it, if both are pulling the same current, and one gets hotter, it has to be a heat sinking problem. The law of conservation of energy says the energy has to go somewhere, and it apparently isn’t staying in the hot end of the setup, unless the thermistor is lying.
You know what you have a point. Don’t know why I overlooked that fact. It is getting slightly more current than the left extruder so it should be getting just as hot as the left assuming nothing of the right extruder is different than the left. In that case a faulty thermistor which gives an incorrect reading would definitely lead to this issue. The only way to verify this is to switch both thermistors and put the right thermistor in the left hot end and the left one in the right hot end. Good catch Ed!
Also, I think your motherboard can not handle it. I think you should shut of the right nozzle, To make sure and try to give the left nozzle all the attention.
I’d agree with this except that when he tested both the voltage and current to both nozzles. The right nozzle ( the one that doesn’t achieve the desired temperature) does get the same voltage but more current. So in theory it should be hotter than the left nozzle. The running idea is that the thermocouple is not telling the truth for the right extruder. it seems that is causing the heating element to continually use the same current as if it was heating from cold start. The only way we can check is to swap thermocouples from left to right and right to left to see if the problem goes away in the right extruder but presents itself in the left. If that’s the case then we identified the problem to be the thermocouple.
I just realised you replied to my post about the upgraded 80w hot end. In that case if you were talking about the upgraded hot ends not working with the motherboard then I agree with that statement and you can disregard my last reply.
I would try swapping thermocouples and plugs at the PCB to see if the problem follows to the other side while heating, that way you know if it’s a faulty thermocouple or not.
Likely, you have broken your heater cartridge when doing the replacement. They have very tiny wires, and are very delicate.
If the same current and voltage is flowing into both heaters and one is hotter, either the themocouple lies, OR the heat is going somewhere it shouldn’t.
The thermocouple would lie if:
  1. It is defective.
  2. It isn’t attached to the aluminum block with thermal integrity.
  3. The wiring is faulty.
  4. The A-D converter in the microprocessor is faulty (not likely)
  5. The firmware interprets the reading incorrectly (not likely)
The heat would be going somewhere if:
  1. There is too much heat conductivity from the hot end through the tube to the feeder block (across the thermal barrier built into the tube).
  2. Too much cool air across the hotend from a fan.
  3. Operation in very cold conditions (not possible for only one of two extruders).
Swapping components is a good way to troubleshoot.
I agree with you on that one. Try swapping the sensors to test them and you should see if the problem moves to the left hot end after the swap.
Flashforge Product Inquiry
Mini Wang-Flashforge
1) Improve the installation method of the extruder to have better temperature protection. Because if the extruder is cooled down by the fan, the power will be waste. So, if the temperature is well reserved, 40W is strong enough;
2) If above method does not workable for you. We suggest you change a power supply with larger power, say 400W, then you can have a 80W cartridge heater. Because our current power supply is about 320W, if all electronic components work at the same time, the power supply may not able provide enough power.
Hope this helps. Thank you.
