Well it definitely seems like the firmware, motherboard and thermocouple is working. Since the right extruder is not at the correct temperature the thermocouple is telling the motherboard and hence the firmware that it needs to supply more current to heat the hot end some more. What seems odd is that you are using more current on the right hot end than the left and yet the left hot end is reaching a higher temperature. Since you have ruled out the heatsink thermopaste we seem to of isolated it to the heating element in the right hot end. I would say that maybe by switching to a full metal hot end it put more stress on the heating element which caused it to fail. Since after reading multiple places and having the same issue myself with a full metal nozzle, having so much metal causes the hot end to become a heatsink making the heating element stress more to maintain temperature. I’ve noticed this when converting to a full metal nozzle where with a brass nozzle I could get to 260 degrees without issue, I couldn’t even make it to 250 degrees with the metal nozzle. I have a hunch that the heating elements arent the best on the flashforge and that’s what you are running in to. I would propose one last test and that is to replace the PTFE setup (only on the right hot end) and see if you can achieve the correct temperature. If everything is exactly as you had it before switching to the full metal hot end and it still doesn’t achieve the correct temperature, then I would say that at this point it is definitely the heating element. Would you be able to submit a picture of the wires on your hot end for the right extruder?
I just realized I didn’t answer your question about the heating cartridges not accepting the power they need. I believe that the left extruder is accepting the power it needs since anything between 1 and 2 amps is within the range I would assume to be acceptable ie. Between 24 and 48 watts per extruder. Since we have a ~ 350 watt power supply I assume a large portion of the power goes to the heated bed and the rest for the motors. Since there are two hot ends I would assume at least 48 watts for both extruders during heating up which leaves 300 watts for the rest. 300 watts does seem like a lot but I assume 150 goes to the heating of the bed since it’s a large object to heat and maybe another 15 watts go to the motors and the rest is overhead since you should never run a power supply at its maximum rated load. Again this is all speculation based on reasoning. Finally the reason why I say the left extruder seems like it is correct and not the right hot end is because the right hot end is getting more current but not doing a good job at heating. Which leads to my previous conclusion that it must of stressed to the point of failure. Sorry for the long replies but you have me thinking ;P.
Should I upgrade to an 24v 80W cartridge then?
You would definitely be able to get to 260 degrees no problem. Just make sure the motherboard can handle such a load. Try asking the company selling the 80w upgrade if the mighty board on the flashforge creator pro can handle the current draw for it. I’m thinking of upgrading my hot ends in the future too because of the lack of heating with metal nozzles. If you do end up upgrading to the 80W would you mind posting to update me on wether it solved your problem or not. I want to see if the upgrade works for you and if it does I’ll probably join you on the upgrade.
If the same current and voltage is flowing into both heaters and one is hotter, either the themocouple lies, OR the heat is going somewhere it shouldn’t.
The thermocouple would lie if:
- It is defective.
- It isn’t attached to the aluminum block with thermal integrity.
- The wiring is faulty.
- The A-D converter in the microprocessor is faulty (not likely)
- The firmware interprets the reading incorrectly (not likely)
The heat would be going somewhere if:
- There is too much heat conductivity from the hot end through the tube to the feeder block (across the thermal barrier built into the tube).
- Too much cool air across the hotend from a fan.
- Operation in very cold conditions (not possible for only one of two extruders).
Swapping components is a good way to troubleshoot.
I agree with you on that one. Try swapping the sensors to test them and you should see if the problem moves to the left hot end after the swap.
Flashforge Product Inquiry
Mini Wang-Flashforge
1) Improve the installation method of the extruder to have better temperature protection. Because if the extruder is cooled down by the fan, the power will be waste. So, if the temperature is well reserved, 40W is strong enough;
2) If above method does not workable for you. We suggest you change a power supply with larger power, say 400W, then you can have a 80W cartridge heater. Because our current power supply is about 320W, if all electronic components work at the same time, the power supply may not able provide enough power.
Hope this helps. Thank you.
I think that insulating the extruder is a good idea. I have been researching just that. Kapton tape isn’t enough. I ordered some of this http://store.quintessentialuniversalbuildingdevice.com/product.php?id\_product=10 and some tape. Some printers come with insulated blocks.
