May 2016
Ah so you think my temp. Is to low I’ve been using maker geeks and pla is needed at 230 and I’ve been trying 200-210 so I’ll try that
No, I think you should decrease bottom layer Line width to 100% and bottom layer thickness to 0.2mm. You will extrude less than half the volume per time unit which is easier to heat up consistantly.
Hi Greg. I see initial layer thickness is still at 0,3mm. Please change to 0,2. Because at 200 percent and 0,3 you were extruding so much filament that it probably compensated a bit for z height error. But at the expense of lines not being wide enough to touch each other. If you do first layer at 100% and 0,2 any z error is much easier to detect. ( and loads on extruder are much lower) Because if to close to the bed, printwidth will become too wide. This becomes visible when infil patterns start to overlap. If to high, lines are not touching. A good workaround is to turn on raft. This will increase the succesrate of many prints and will also compensate most z errors. Good luck
