Mar 2015
I got a FF Creater Pro last november, and it’s started to go wrong!!!
It’s an amazing machine, just keeps going. Till it stops…!
This has been happening for a week or so. It only happens after I have been printing for a while each time…
I printed one model without problem, and then this started to happen with the next one. As you can see from the attachment, the left-right axis (is this x or y?) starts skipping. The model at the front is was the first try, and then the one at the back.
The skipping/slipping starts at random points, so it’s not the model itself. The belt doesn’t seem to be especially loose.
I’m hoping that this is something quick I can fix for myself as I have a couple of other orders backing up…
Any suggestions?
Cris.
    Mar '15
    Nov '15
  • 25
  • 3.9k
  • 12
Hey - Shifting layers can happen when one of the pulleys is not secured properly to the axis/axes. The pulleys may need some tightening with a set screw.
This article 35 goes into a bit more detail troubleshooting this issue - Hope it gets you started in the right direction.
Great answer. Does your FFCPro also suffer from intermittent stops? Or where the printer might cease mid-print and slow move toward the X or Y axis? -Andy
The other thing I’ve seen, though not on the FF, is if the head catches on the print. Can be caused by crud on one of the nozzles, too much plastic being extruded, or the print warping off the bed.
Lyle
About the intermitent stopping, do you get an error message on the lcd screen? I have the FF creator X, and I noticed that I have to keep the bottom of the printer free of any stuff that could prevent a nice clean ventilation. Otherwise, it would freeze.
Thanks guys.
I checked out Alex’s article and made sure all my rod gears were tight. Nothing loose.
So I oiled the rods… Boom. Fixed. I think hairspray residue must have been building up on them, drying them out.
Need to find some proper grease (I used baby oil!!)
I have experienced the exact same problem on my Creator. The problem was the timing pulley slipping on the motor shaft.
Tightening the set screw fixed the problem…for a while. Taking a closer look I realized the set screw was contacting the motor shaft at the very end so it would eventually vibrate itself loose. I had to flip the pulley around on the shaft so the set screw could do its job. Haven’t had a problem since.
I hope that solves your problem. Happy printing!
-Mark
To bring it back to personal lubricants, talking to a colleague, he recommends, that we are talking about indoors, not needing heat or pressure resistance that Vaseline would be a perfect and cheap grease.
I will report back!!!
Make sure acceleration is turned on via the lcd for speed ramping. Large builds may hit the limit switch and make the stepper skip. Check the stepper cable. Wiggle it while printing. Check pullies, tighten belts ect.
Did anyone ever try that Vaseline idea? I don’t have any Lithium grease at the house and I know my rod’s could use something.
Watch this post for the next 3 hours. I’ll let you know!
are you sure the nozzle is not hitting the print? I had to adjust my nozzles the left nozzle was lower and kept hitting anything i was printing with the right nozzle. The result was something like i see in your photo. Once i adjusted them I did not have this issue anymore.
Cool I’ll check back :slight_smile: My other options currently are WD-40 or 3-in-1 oil. But both seem a bit thin. And it’s oil, not grease :stuck_out_tongue:
Or I guess goto the store and buy some is also a option :wink: but not sure when that will be
Right - update…
The Vaseline works great, it’s light and clean, cheap and easy to apply.
But that was not the problem, and it’s got worse…
I can move the easily print head manually, so the motor is not jammed, but when I print, the x axis does not move and it makes a terrible noise like it’s trying and something it stopping it.
I read something a while ago about the cables taking a lot of wear and tear and needing replacing?
Anyone help?
Cris.
Wow. At this point, I would check the stepper itself? I never had to do that though, but that would be my first next step: trying to remove the belt and see if it rotates using the lcd panel manual commands.
hmmm… Hadn’t thought of that. Without taking the belt off, X-jog commands work fine, but then it always seems fine when I first switch it on…
Need to go to work now, will experiment more later.
I’m not sure if you got it or not yet, but if not, and hopefully link’s are aloud here, I would check out www.3dprintboard.com 7 , they have a whole section for Flashforge, with a lot of people that know the in’s and out’s of the machine. I almost guarantee you can find your answer there if not yet :slight_smile:
If it’s only occurring after some time has passed, it could well be that the motor is on it’s way out? I would hate to think so, but I can only suggest swapping the X and Y stepper motors around to see if the problem moves with it.
- Andy
i think your Stepping drivers are over heating! i used to get this exact problem with Ramps Electronics, put a bit cooling fan over them and the problem went away! maybe if you can open up the area where the Electronics are and get a fan to blow air across and see if it makes a differance!
Good Luck
16 days later
well… I ended up having this same problem… The stepper would make a grinding noise then the print would shift to the right. creating steps. I re-wired the x axis stepper and the problem was solved.
7 months later
I am having a very similar problem.
In my case after about 10 minutes of printing, I will get a very brief grind from the stepper motor, which will cause a shift in the x-axis. A few minutes later the unit grinds terribly and the head travels randomly off the print grinding the whole time.
This appears to be an electronic issue, I have checked all set screws and oiled the rods. The x-axis will not jog making the same vibrating/grinding noise *until* I power cycle the machine. After a reset, the jog test on the motors is as smooth as can be.
I am experimenting with possible high temperature issues and am considering buying replacement cable, motor controller and Stepper motor.
By re-wired do you mean you replaced the wires between the stepper motor and controller? Or the wire running from the controller all the way back to the mainboard?
24 days later
UPDATE: RESOLVED
My shifting issue and stepper motor grinding problems have been resolved. Since the company was paying for it I ordered a replacement stepper, controller and cable that runs between them. I then replaced the parts one at a time.
It was the cable. This thing is working better than new. Apparently that cable has been a problem for some time.
