Apr 2017
I am running a Dremel 3d20 with about 600 hours. This is my first printer, and I had some early sucesses but lately, it jams after about an hour of printing.
I have had the most luck with settings, slowing everything way down, but I don’t know what else to try.
It’s properly leveled, not dragging, and I preheat before the print. Could something be wrong with the extruded nozzle?
Are you using hatchbox or dremel pla? Sounds like the pla is cooling in the extruder.
Cool! I may try that. I am also putting the filament out of te printer so that it doesn’t have to arc over and rub on everything. Going to hang the roll from the ceiling right over the machine.
No problem :slight_smile:
yea you should do that. Last time I also use IKEA zip log bag. Bad idea. Some time the friction force is too much will course jam and uneven flow :frowning:
Maybe you can try run with closing cover. For me the print quality is better. Air con room :slight_smile:
I am in control of the ac in my classroom, so I can turn it off.
turns out, print studio has the temperature controls locked out, so I can’t tweak that. But if it’s cooling too fast in the nozzle, maybe I am also doing this backwards— in stead of slowing down all the speeds, maybe I should speed up and get it out before it cools?
Not sure about print studio. My one work at 3000mm/m at 220. I using simplify 3D.
Filament should not cool in nozzle unless something wrong.
