May 2017
I’m not quite sure how to minimize the gap between the endstop and carrier. Is the left fan not needed?
If you align the object to print in the lower left corner of the cura bed… where the printer prints?
The printer prints correctly on the Y axis (front of the bed), but prints a couple cm to the right of where it should on the x axis.
Ok, now take a pic of Cura settings like I took it, to show me the offset you set, please.
12 days later
I looked up pictures of my printer on google, and noticed that none of them had the left fan installed. I then removed the left fan from my printer and that solved the problems. I have had no temperature issues, so I think the problem is solved. Thanks for all the help!
it’s not a good practice. The upper part of the hotend will become very hot melting the filaments that could melt inside and get stuck inside. Perhaps it could be nice for ABS, but not for PLA.
What would you recommend, as changing the offset did not effect the printer at all?
