May 2017
I can see on the left of the carrier too much space between the carrier itself and the x-end stop. If A3 assumes that the x-origin point is for example 2cm at left of the bed it considers that the real start point is that… then you have to add a gap in x to correct it. Later I’ll send you some pics
I don’t use Cura for Afinibot A3, but Repetier-host and Slic3r. This solution permits to set the offset before the nozzle reaches the bed. I presume that in Cura You can try to adjust as need the value where i mark with a red circle. I don’t know if you have to use negative values… (it could be).
Measure the distance between the nozzle when in x-home and the left corner of the bed. Put the value in the first field (probably negative).
I’m not quite sure how to minimize the gap between the endstop and carrier. Is the left fan not needed?
12 days later
What would you recommend, as changing the offset did not effect the printer at all?
