I’m wondering if anyone is willing to help me with a 3d model request now it’s nothing excessively complicated but what I need is a 3d model of the item in the image, I’m looking to get two models made one in a standard US size 14 ring and one in a US size 13 1/2 ring, now please consider that the model is of something small and somewhat easy to make so don’t expect me to agree to some insanely high commission fee. The main reason why I need these in the specified ring sizes is that they aren’t made in the size I need especially since they’re for a cosplay
Hi Magus
Do you have a stl file or can you get them 3D scanned? Failing that, you would need to draw them in 3D first.
Can you post a photo of the side and top aswell please?
Cheers
Adam
Sorry, just realised it should have been Eric, not Magus!!
Adam
Do you have a top view? Do you want all the detail or just the ring shape with a flat surfaces ( no detail ). I can give it a try for you.
What’s your budget?
I could help you out with the 3d modeling, given you’d be able to provide more pictures and reference measurements. I’ll assume, that the top surface isn’t that complex, so the modeling cost would be around 10-20$ per individual ring (unless only the size should be changed, then the 2nd one is much cheaper). That’s just a quick estimation and the price may go up or down depending on the additional pictures. Contact me by clicking on the icon below this comment. Clicking will lead you to my hub, where you can start an enquiry in order to discuss more details etc. Cheers, Marius Breuer
I can model the shape(<$50) and print in whatever material/size you like, but If you want all the surface detail I would need more picture for an estimate. Let me know if I can help.
https://www.3dhubs.com/miami/hubs/mindfull
-Jesse
here are some side and top view shots, the top part where it’s flat has to stay the same size, the only thing that needs to change is the ring part as I said one model in a size 14 us standard ring size and another model in a size 13 1/2 standard ring size, also seeing as how the models are simple in design I’m keeping my budget to around 40 dollars seeing as how it’ll cost me quite a bit to get 14 of the size 14 rings printed and around 40+ of the size 13 1/2 rings
Hello! Here is a start of 3D Models. How much detail do you want?!
Cheers!
Christopher
gonna need the exact same amount of detail as the ones in the pictures, also the top plate has to be at exact measurements so I’ll snap some new photo’s with a measuring tape next to the ring
took a little while due to the chaos that is life but here’s new reference shots of the top part of the ring with a measuring tape in the shot to give an idea of the measurements
did everyone who posted seriously jump ship because of the budget I set
If you want to, I could help you out with the 3d model, also with a pricing that’s within your budget. Contact me via my hub by clicking on the profile icon below this comment. I’d like to hear from you. Cheers, Marius Breuer
Hello! Still here, little more detail on the rings…
ahh, impressive, sorry thought everyone up and ditched since I put up such a low amount for what I’d pay for the 3d model commission
missed one angle shot
These are now closer to the “tape measure” sizes. Not sure I can get all that detail in these models “time efficient”. Plus added cost of 3D Printing I have access to. I could provide STL files, if you have a printer, as “prototypes”. I sized the rings off a ring size guide I found on the internet. The “diameter” is the inside of the hex…
those honestly look amazing the only thing missing is the little nub at the center of the top piece, I personally don’t have a printer I was, probably going to print it through 3d hubs someplace close to me
Hi
I’m following your progress, but assume as I’m based in UK it wouldn’t be viable for me to price it for you.
I notice that Christopher has drawn the ring as a hexagon and not an octagon! Whoops!!!
Cheers
Adam
that looks pretty good although I have other reference images that give the measurements for the top rectangular part which has to be exact
so is that scaled to a US size 14 ring? as I said I need one model in the previously mentioned size as well as one in a size 13 1/2
