Hey Nic,
I have Windows 8, so I’m not sure. I specifically bought a laptop with Windows 8 to make sure it worked.
This forum has been a big help, though, so I’m sure they can give you some direction.
Good luck!
matt
nicmar
22
ok, I solved the issue! I went back to windows 8.1!
did anyone get to the bottom of the opengl32.dll issue under windows 10? I am running (or trying to run) the latest version of Z-Suite.
It is certainly not a hardware problem, as Z-Suite was running fine on the same hardware under windows 8 - it was only under the windows 10 install that it has stopped working.
I have ensured I have the latest .net framework installed - and rebooted, and reinstalled z-suite - with no success.
I have tried with AVG and Defender disabled - with no success.
I have tried installing and running under Windows compatibility mode for XP, Vista, Windows 8 - with no success
I have tried replacing the openg32.dll file with an fresh version from another working windows 10 machine - with no success
I have refreshed and updated all my Windows display drivers to latest versions - with no success
Any ideas?
thanks for your suggestions -appreciated.
cheers
ERROR IMAGES.pdf (284 KB)
