Jan 2016
You have to install the frameWorks.
you can find it on the zortrax web site
Thanks for your reply! I’m on the Zortrax website, and all I see is the software, and the firmware - is the firmware the same thing as the frameworks? If not, do you know where exactly I can find the frameworks?
Thanks!
matt
Hey, thanks for the suggestion.
So, which combination of software and mono framework would you suggest? I see there are three options for each, and I’m not sure which to use for optimum performance.
Thanks!
matt
That’s what I’ve been running, too.
Do you have problems when you add multiple items to the build plate? I’m trying to print about five items, and every time I try to add multiple models to the build plate, the software stalls and crashes.
Hello your system hardware of your PC does not support the ZSuite, try to upgrade or replace the PC you have with a more 'performance, hello.
The software is supposed to be compatible for Windows XP - Windows 10. I’ve tried it on Windows XP and Vista. What would you suggest?
Thank you!
matt
hello, your problem almost certainly depend from VGA, probably is old hardware and is’nt opengl’s compatible…
excuse me for bad english…i’m italian…hello
What you can try is before you install the software switch off your antivirus software. I had some trouble as well with that.
Hello,
Its most likely caused by outdated graphic drivers. Since XP is not supported by Microsoft anymore, we can’t guarantee that will work there. As far as I know, Vista is causing some troubles as well, but error shown on your pic indicates VGA problems.
Hey Marcin,
Thanks for the info. What Windows OS would you recommend, then? Anything past Vista?
Thanks!
matt
Hi matt,
did you solve the problem?
I have the same issue with windos 10.
if you have any ideas let me know.
Thank you
Nic
yes,
i have .net framework 4.6.1
i was thinking the same but i have it.
Hey Nic,
I have Windows 8, so I’m not sure. I specifically bought a laptop with Windows 8 to make sure it worked.
This forum has been a big help, though, so I’m sure they can give you some direction.
Good luck!
matt
6 months later
did anyone get to the bottom of the opengl32.dll issue under windows 10? I am running (or trying to run) the latest version of Z-Suite.
It is certainly not a hardware problem, as Z-Suite was running fine on the same hardware under windows 8 - it was only under the windows 10 install that it has stopped working.
I have ensured I have the latest .net framework installed - and rebooted, and reinstalled z-suite - with no success.
I have tried with AVG and Defender disabled - with no success.
I have tried installing and running under Windows compatibility mode for XP, Vista, Windows 8 - with no success
I have tried replacing the openg32.dll file with an fresh version from another working windows 10 machine - with no success
I have refreshed and updated all my Windows display drivers to latest versions - with no success
Any ideas?
thanks for your suggestions -appreciated.
cheers
ERROR IMAGES.pdf 5 (284 KB)
