Jan 2016
Hi Zortraxers!
Is any way to clone and automaticly reposition models inside Z-Siute? Or the only option is to drag and drop from folder? What if I open model directly from other aplication?
    Jan '16
    Jan '16
  • 12
  • 3.4k
  • 10
select the object then press ctrl+C
it add a new copy of the selected object
press ctrl+C as many times you need
Select the part or parts you want to copy then press ctrl and c simultaneously on the keyboard to generate a copy. Repeat for as many copies as you wish.
If I remember correctly, unlike some programs, you don’t have to press ctrl v. Just pressing ctrl c generates the copy.
And then click the auto layout button on the left bar to have them laid out ready for printing :slight_smile:
Right mouse click the original model then press control-c (two keys together) you can make as many copies as you like. Auto repositioning is easy - second icon up from the bottom - just hover over the icons to find out what each one does.
highlight the thing once you have it dropped in. then press Ctrl + c as many times as you want do not worry if you go outside the area so to speak. when you have the desired amount push auto arrange and Robert is mothers brother.
Also… If you need a mirrored part just copy and scale to negative 1.
